Linking User Libraries
blwiland
I created a IVF library that consists of various subrountines I use in multiple projects.When I addthis library name (and correct path) to the project Configuration Properties/Linker/Input/Additional Dependencies, the linker does not seem to find it and gives a "fatal error LNK1120: 1 unresolved externals" and identifies the unresolved external symbols as one of the subroutines that should be in my library.
Is there something else I need to do to get the project to recognize the subrountines in this library?
Paul_Curtis
Valued Contributor I
Add your library to the project itself via Solution Explorer, similar to adding another source code module. (And of course your code will need INTERFACEs for the library routines.)
