Linking error with Modflow build in VisualStudio 2013
jauliest
Hi All,
I need your help. I'm compiling Modflow2005 in visual studio with intel fortran project in debug mode, but when the link process is reached out the follow error:
Error    12     error LNK2005: _MAIN__ already defined in hydfmt.obj    mnw1to2.obj
Error    13     error LNK2005: _IFRL already defined in mnw1to2.obj    gwf2mnw17.obj
Error    14     error LNK2005: _NCREAD already defined in mnw1to2.obj    gwf2mnw17.obj
Error    15     error LNK2005: _QREAD already defined in mnw1to2.obj    gwf2mnw17.obj
Error    16     error LNK2005: _MAIN__ already defined in hydfmt.obj    mf2005.obj
Error    17     fatal error LNK1169: one or more multiply defined symbols found    Debug\modflow.exe
My compiler is Intel Parallel Studio XE 15.0 + Visual Studio 2013 Pro, upload the source code 446398
Tanks,
Ulises
jauliest
I find the error tanks
mecej4
You can only have one main program; you can have only one instance of a subroutine or function subprogram among all the object files being linked to build an executable. For example, there is an unnamed main program in file mnw1to2.f, as well as a named main program in file hydfmt.f.
Not knowing anything about Modflow, I cannot tell you which files you should set aside.
jauliest
Tanks
