I have downloaded the demo version Linux Fortran compiler but the installer only offers 32-bit options. Where can I find the 64-bit demo?
Register the serial number you were sent at the Intel Registration Center. Log in to Intel Premier Support, select File Downloads. You will find the EM64T compiler there - look for a file wil a name starting with l_fce_.
The Evaluation Center's registration page rejects passwords. The error message is "ERROR: User's password is too weak for this role. A stronger password is required (25253)" The last two passwords I tried are "%%41g@kU5$" and "2:idJDCA". I do not know how to make stonger passwords.
I'll pass on your complaint to the registration center people. I know they are working on easing the password restrictions.
Here are the password rules at present:
* The password must be at least eight and less then 15 characters long
* It can contain letters, numerals and punctuation
* It cannot contain spaces
* It must contain at least one alpha character [a-z, A-Z]
* It must contain at least one numeric character [0-9]
* It must contain at least one special character from the following list: ` @ & ; ' " , ! $ % ^ * ( ) - _ = + [ ] : < . > ?
* It cannot contain any special characters not in the above list
* It cannot begin with an exclamation point (!) or a question mark (?)
* The first three characters cannot be the same
* Passwords are treated as case sensitive
When you get an acceptable password, you may want to post a problem report about that message. It looks like it wants weaker, in terms of not using certain characters. I would have thought the Help button should let you see the criteria, such as requiring a mixture of alphabetical, numeric, and a small list of punctuation characters.
