Linux- library of pgmp
zhangquan09
This is a segment from a Makefile for fortran codes "LINKS = -L$(NETCDFLIB) -lnetcdf -llapack -lblas -lpgmp -lpthread", what does the "pgmp" stand for?
Zhang
TimP
You are looking at pgf90 options. You should translate the lapack, blas, and OpenMP options to those which are documented for the compiler you are using.
ifort -openmp supplies -liomp5 -lpthread automatically.
The lapack and blas options for Intel compilers are to be found by running the tool from the MKL forum page
zhangquan09
Dear tim18
My compiler is intel fortran.
You mean I need to install or compile an OpenMp as a subsititution of "pgmp" which is an pgf90 option?
"ifort -openmp supplies -liomp5 -lpthread automatically."??
How should I do it?
Thank you!
Zhang
TimP
Where pgf90 uses -mp, ifort would use -openmp. Where pgf90 could use -lpgmp, ifort could use -liomp5, but it's usually better to use the -openmp option so that ifort itself chooses -liomp5 -lpthread.
