using a floating license server, local admin accounts do not get the "Time Machine" error listing, but admin accounts authenticated with Active Directory get the exclusion error mesage.
2011-10-14 10:44:19.035 ifort[55659:303] This process is attempting to exclude an item from Time Machine by path without administrator privileges. This is not supported.
2011-10-14 10:44:19.039 ifort[55659:303] This process is attempting to exclude an item from Time Machine by path without administrator privileges. This is not supported.
ifort version 12.1.0
2011-10-14 10:44:19.035 ifort[55659:303] This process is attempting to exclude an item from Time Machine by path without administrator privileges. This is not supported.2011-10-14 10:44:19.039 ifort[55659:303] This process is attempting to exclude an item from Time Machine by path without administrator privileges. This is not supported.ifort version 12.1.0This is the first test with 12.1.0 update 6, and Lion 10.7.2
Thanks for the information. The suggestion as running as root does not change the problem for a local user on 10.7.2, or even an admin user using Active Directory authentication.
THe executable is createdjust fine, but I still get the "TIme Machine" listing, which is annoying.
The fix for this problem should be available in the next update to the 12.1 compilers which is currently scheduled for February 2012.
