29376 Discussions
List directed read - character length limit?
Les_Neilson
Valued Contributor II
Is there a limits to the number of characters that can be read using list directed input ?
I have a text file :
999
7.7
'A very long character string (2144 characters) terminated with a single quote'
A hex view of the file shows each record ends with CR/LF pairs (0D0A)
There are no "special" characters in the third line which is a concatenation of a filename, some other text and alist of labels all 40 characters long and currently containing the word "null" followed by 36 spaces. (The labels were originally 16 characters long I havejust changed them to 40)
The file is read using the following code :
spfline = 0 ! A line counter
! read the '999' card
spfline = spfline + 1
read (spfunit,*,iostat=ier) ilen ! No problem : reads 999
if (ier/=0) goto 99999
! version number
read (spfunit,*,iostat=ier) ver ! No problem : reads 7.7
! name
read (spfunit,*,iostat=ier) name ! It is failing here with ier = 59
Name is declared as character(3072)
and the help says that error code 59 is :
"severe (59): List-directed I/O syntax error
FOR$IOS_LISIO_SYN. The data in a list-directed input record had an invalid format, or the type of the constant was incompatible with the corresponding variable. The value of the variable was unchanged."
I have attached a cut down version of the text file.
If, in debug mode, I alterIER to be zero after the failed read, the code then goes on to correctly read the remainder of the file.
Is there a limit on list directed read of a character string?
Or is there something in the third line that I have missed?
Les
The documented limit is 2048 characters. (Building Applications > Reference Information > Compiler Limits)
Les_Neilson
Thanks Steve I was looking under the IO sections in the language reference. I didn't realise it could be a compiler limit. Fortunately changing the format from * to (a) works in this instance.
Les
