Listview control
tropfen
i am using a listview control. I would like to perfom two tasks.
- reseting the content
- not allowing the sort function for columns
Is there a way to do it? ( I am using Xeffort and IVF 10)
Thanks in advance
Frank
Jugoslav_Dujic
Valued Contributor II
tropfen:
Something which I, admittedly, didn't think about, and should be considered for the next release. You can use XCtlSendMessage(xDlg, IDC_LIST, LVM_DELETEALLITEMS, 0, 0). For virtual list-view controls, CTL_NUMITEMS zero would also work
tropfen:
Ah, that's documented in the Overview (and hopefully works smiley [:-)] ) -- "To disable sorting altogether, use "No sort header" style (LVS_NOSORTHEADER)"
