MKL library with IMSL
rafadix08
I am trying to use the MKL library with IMSL.
I followed the steps in this website:
http://software.intel.com/en-us/articles/intel-math-kernel-library-intel-mkl-for-windows-using-intel-mkl-with-imsl-fortran-numerical-library/
However, when I compilemy code I receive many compilation errors in:
mkl_vsl.fi
Here are the errors I receive (in case it is helpful):
1>C:\Program Files\Intel\Compiler\11.0\075\fortran\mkl\include\mkl_vsl.fi(796): error #6617: The END statement for a CONTAINed procedure is missing
1>C:\Program Files\Intel\Compiler\11.0\075\fortran\mkl\include\mkl_vsl.fi(796): error #6702: END statement confusion
1>C:\Program Files\Intel\Compiler\11.0\075\fortran\mkl\include\mkl_vsl.fi(800): error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MKL_VSL_TYPE]
1>C:\Program Files\Intel\Compiler\11.0\075\fortran\mkl\include\mkl_vsl.fi(810): error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MKL_VSL_TYPE]
1>C:\Program Files\Intel\Compiler\11.0\075\fortran\mkl\include\mkl_vsl.fi(811): error #6457: This derived type name has not been declared. [VSL_CONV_TASK]
1>C:\Program Files\Intel\Compiler\11.0\075\fortran\mkl\include\mkl_vsl.fi(820): error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MKL_VSL_TYPE]
1>C:\Program Files\Intel\Compiler\11.0\075\fortran\mkl\include\mkl_vsl.fi(821): error #6457: This derived type name has not been declared. [VSL_CONV_TASK]
1>C:\Program Files\Intel\Compiler\11.0\075\fortran\mkl\include\mkl_vsl.fi(830): error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MKL_VSL_TYPE]
1>C:\Program Files\Intel\Compiler\11.0\075\fortran\mkl\include\mkl_vsl.fi(831): error #6457: This derived type name has not been declared. [VSL_CONV_TASK]
1>C:\Program Files\Intel\Compiler\11.0\075\fortran\mkl\include\mkl_vsl.fi(840): error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MKL_VSL_TYPE]
1>C:\Program Files\Intel\Compiler\11.0\075\fortran\mkl\include\mkl_vsl.fi(841): error #6457: This derived type name has not been declared. [VSL_CONV_TASK]
1>C:\Program Files\Intel\Compiler\11.0\075\fortran\mkl\include\mkl_vsl.fi(850): error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MKL_VSL_TYPE]
1>C:\Program Files\Intel\Compiler\11.0\075\fortran\mkl\include\mkl_vsl.fi(851): error #6457: This derived type name has not been declared. [VSL_CORR_TASK]
1>C:\Program Files\Intel\Compiler\11.0\075\fortran\mkl\include\mkl_vsl.fi(860): error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MKL_VSL_TYPE]
1>C:\Program Files\Intel\Compiler\11.0\075\fortran\mkl\include\mkl_vsl.fi(861): error #6457: This derived type name has not been declared. [VSL_CORR_TASK]
1>C:\Program Files\Intel\Compiler\11.0\075\fortran\mkl\include\mkl_vsl.fi(870): error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MKL_VSL_TYPE]
1>C:\Program Files\Intel\Compiler\11.0\075\fortran\mkl\include\mkl_vsl.fi(871): error #6457: This derived type name has not been declared. [VSL_CORR_TASK]
1>C:\Program Files\Intel\Compiler\11.0\075\fortran\mkl\include\mkl_vsl.fi(880): error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MKL_VSL_TYPE]
1>C:\Program Files\Intel\Compiler\11.0\075\fortran\mkl\include\mkl_vsl.fi(881): error #6457: This derived type name has not been declared. [VSL_CORR_TASK]
1>C:\Program Files\Intel\Compiler\11.0\075\fortran\mkl\include\mkl_vsl.fi(890): error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MKL_VSL_TYPE]
1>C:\Program Files\Intel\Compiler\11.0\075\fortran\mkl\include\mkl_vsl.fi(891): error #6457: This derived type name has not been declared. [VSL_CONV_TASK]
1>C:\Program Files\Intel\Compiler\11.0\075\fortran\mkl\include\mkl_vsl.fi(900): error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MKL_VSL_TYPE]
1>C:\Program Files\Intel\Compiler\11.0\075\fortran\mkl\include\mkl_vsl.fi(901): error #6457: This derived type name has not been declared. [VSL_CONV_TASK]
1>C:\Program Files\Intel\Compiler\11.0\075\fortran\mkl\include\mkl_vsl.fi(910): error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MKL_VSL_TYPE]
1>C:\Program Files\Intel\Compiler\11.0\075\fortran\mkl\include\mkl_vsl.fi(911): error #6457: This derived type name has not been declared. [VSL_CONV_TASK]
1>C:\Program Files\Intel\Compiler\11.0\075\fortran\mkl\include\mkl_vsl.fi(920): error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MKL_VSL_TYPE]
1>C:\Program Files\Intel\Compiler\11.0\075\fortran\mkl\include\mkl_vsl.fi(921): error #6457: This derived type name has not been declared. [VSL_CONV_TASK]
1>C:\Program Files\Intel\Compiler\11.0\075\fortran\mkl\include\mkl_vsl.fi(930): error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MKL_VSL_TYPE]
1>C:\Program Files\Intel\Compiler\11.0\075\fortran\mkl\include\mkl_vsl.fi(931): error #6457: This derived type name has not been declared. [VSL_CORR_TASK]
1>C:\Program Files\Intel\Compiler\11.0\075\fortran\mkl\include\mkl_vsl.fi(940): error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MKL_VSL_TYPE]
1>(2192): catastrophic error: Too many errors, exiting
How are you using mkl_vsl.fi? If you are INCLUDEing it, the INCLUDE line needs to be first in your source, before any other statements, since it actually defines a module. I don't care for the way they have done this - it really should be given a .f90 file type since it is just a MODULE.
rafadix08
Steve,
I was including it inside a subroutine. Your recommendation worked. Before the declaration of the module that contained the subroutine I added a line with "include 'mkl_vsl.fi' " and it worked.
Many thanks,
Rafael
