29407 Discussions
Mac old DWARF debug info - rebuild with newer compiler
mdekauwe
When I tried to build a program with the debug flag I get the following error
ld: in getmet.o, object file contains old DWARF debug info - rebuild with newer compiler
this problem seemed to be a bit similar to this posting:
http://software.intel.com/en-us/forums/showthread.php?t=62184
Where there is mention of un-installing gdb being the issue. I recently (installed a new version of gdb), though I don't understand the issue with gdb so not sure how to correct this?
I am using
GNU Make 3.81
ifort 11.1 20
GNU gdb (GDB) 7.2
Many thanks
mdekauwe
I should add this happens even with a simple test case e.g.
PROGRAM hello_world
IMPLICIT NONE
PRINT *, "Hello World"
END PROGRAM hello_world
ifort -g -o hello hello_world.f90
