29641 Discussions
Macro for getting source code line number
giovanni_81
I was wondering if exists (in Visual Fortran 10.1.029) some kind of macro/directive that allows to get the current source code line number.
In fact, in a WRITE statement I would like to put as part of the output string the current line code.
Does anything similar also exist to get the current source code file name?
Thank you,
regards.
thomas_boehme
New Contributor II
Quoting - giovanni_81
Thank you,
regards.
You can use the C-preprocessor for that.
You need to set Fortran->Preprocessor->Preprocess Source File to YES, then you can use __LINE__ to get the line number in the code.
Thomas
