Make intent in array be global
Stephen_W_
I wonder how to make the array `array1` be global (module) variable, consider following code
module data
    implicit none
    real(8), allocatable, dimension(:,:) :: A
end module data
subroutine test(array1, n, m)
    use data
    implicit none
    integer, intent(in) :: n, m
    real(8), intent(in), dimension(n,m) :: array1
    allocate(A, source=array1)
    do_something
end subroutine test
`allocate(A, source=array1)` works but double store the same array, `save` is another method but not satisfied.
Arjen_Markus
I am not entirely sure what you want to achieve, but you could define the array A to be a pointer:
module ..
     real(8), dimension(:,:), pointer :: A
end module
subroutine ...
     real(8), dimension(:,:), target :: array1
     A => array1
end subroutine
You have only one copy of the array then, but make sure that the array1 remains "alive" as long as you want to use A, while pointing to array1.
It might be better to move the allocation, via call move_alloc - array1 must be an allocatable array/pointer to an array. That way you transfer the memory to A and you only have to worry about the "aliveness" of A.
Arjen_Markus
module ..
end module
subroutine ...
     A => array1
end subroutine
Steve_Lionel
A is already "global" - I too am not sure what you want to happen differently. As you have it, the allocate of the global array A occurs in the subroutine and the dummy argument array1 is copied into it - that's what source= does. There is no double store. What would you like to happen? Really, you don't need subroutine test at all - the ALLOCATE will do everything.
Do not use pointers here.
Stephen_W_
Sure, A is already global, but does not initialized, I just want dummy argument array1 be global, and the subroutine test will be called by other language.
Stephen_W_
module ..
end module
subroutine ...
     A => array1
end subroutine
Many thanks, I have tested the pointer solution, yes, only one copy of the array.
