29363 Discussions
Making DLL arguments part of a module
Pramod_V_
I am trying to make the arguments of a subroutine be part of the module so other subroutines can use it. Is there anyway to make this work without having to assign local variables (testDLL's a and b) to global variables (TestMod's a and b)? I am trying to avoid assignments as much as I can.
   module TestMod
      real :: a
      real :: b
      real :: c
   contains
      subroutine testDLL ( a , b )
      implicit none
      !DEC$ ATTRIBUTES DLLEXPORT::TestDLL
      call otherSub1 ()
      end subroutine testDLL
      subroutine otherSub1 ()
      implicit none
      c =  ( a + b ) * 5.0
      end subroutine otherSub1
   end TestMod
Steven_L_Intel1
No. Module variables are globals (and static), But you could do this:
module TestMod
contains
   implicit none
   call otherSub1 ()
   contains
   implicit none
   c =  ( a + b ) * 5.0
end TestMod
(I note that you don't declare c here, but you'll get the idea,) When testDLL calls otherSub1, any local variables in testDLL are visible in the contained subroutine otherSub1. Yes, you can have a contained procedure within a module procedure.
Steven_L_Intel1
module TestMod
contains
   implicit none
   call otherSub1 ()
   contains
   implicit none
   c =  ( a + b ) * 5.0
end TestMod
