I am trying to make the arguments of a subroutine be part of the module so other subroutines can use it. Is there anyway to make this work without having to assign local variables (testDLL's a and b) to global variables (TestMod's a and b)? I am trying to avoid assignments as much as I can.
module TestMod
real :: a
real :: b
real :: c
contains
subroutine testDLL ( a , b )
implicit none
!DEC$ ATTRIBUTES DLLEXPORT::TestDLL
call otherSub1 ()
end subroutine testDLL
subroutine otherSub1 ()
implicit none
c = ( a + b ) * 5.0
end subroutine otherSub1
end TestMod
No. Module variables are globals (and static), But you could do this:
module TestMod
contains
implicit none
call otherSub1 ()
contains
implicit none
c = ( a + b ) * 5.0
end TestMod
(I note that you don't declare c here, but you'll get the idea,) When testDLL calls otherSub1, any local variables in testDLL are visible in the contained subroutine otherSub1. Yes, you can have a contained procedure within a module procedure.
module TestMod
contains
implicit none
call otherSub1 ()
contains
implicit none
c = ( a + b ) * 5.0
end TestMod
