Making statically-linked files
Harry_A_
I am using 18.0.0.124 {IA-32] with Microsoft Virtual Studio community edition 2015.
I need to know how to make a statically-linked Fortran program.  I want to include all the necessary DSLLs in the output file.
TimP
You may be able to make full static .exe by avoiding OpenMP/parallel and using /MT link switch or equivalent VS property.  But my docs say that the 2018 ifort has gone back to making this the default (?).
Steve_Lionel
Static linking is the default from the command line, but DLL linking is the default in Visual Studio projects. I don't think this has changed in several years. Two kinds of Fortran run-time support are DLL-only: OpenMP and coarrays.
In your Visual Studio project properties. select Fortran > Libraries > Use Run-Time Library > Multithreaded (/MT).
andrew_4619
in addition to Steve's comment (Maybe it implies openMP)  /Qparallel also makes it non-static linking
