29422 Discussions
Manifest Tool: Same option settings, different command line
Martin_B_2
In two projects I have the same property settings of the manifest tool. Nevertheless I get different command lines.
I have thought, the command line is just a summary of the settings. Am I wrong?
General.bmpInput_and_Output.bmpIsolated_COM.bmpAdvanced.bmpCommand_Line_HDKurve.bmpCommand_Line_HDK4UG.bmp
It would appear, from my research, that /notify_update is an undocumented option that Visual Studio inserts. Do you have a resource file in one project and not the other? This might be the key. In any event, it is not tied to any project property.
Martin_B_2
How can I identify a resource file? What kind of an extension does it have?
mecej4
Perhaps, for most items. However, some parts of the command line(s) may be generated (based on some appropriate rules), in which case I suspect that the command line could be affected by the presence of pragmas and directives in the source files being compiled.
A resource file has extension .rc. I don't know for sure that this is relevant - information on this option is very sparse and it tends to just get mentioned in passing.
My advice is to not worry about it.
Martin_B_2
There are rc-files in both projects.
