Matrix as a formal parameter
gryvon
If an array is described in a subroutine larger than in the main program, it is not transferred correctly. Here is the source.
program bpro
implicit none
external :: bsub
integer*8 :: i, j
real*8, dimension(1:3, 1:3) :: a
a(1, 1) = 1.0d0
a(1, 2) = 2.0d0
a(1, 3) = 3.0d0
a(2, 1) = 4.0d0
a(2, 2) = 5.0d0
a(2, 3) = 6.0d0
a(3, 1) = 7.0d0
a(3, 2) = 8.0d0
a(3, 3) = 9.0d0
write(6, '(3D25.16)') ((a(i, j), j = 1, 3), i = 1, 3)
write(6, *)
call bsub(a)
stop
end program bpro
subroutine bsub(array)
implicit none
real*8, dimension(1:10, 1:10) :: array
integer*8 i, j
write(6, '(3D25.16)') ((array(i, j), j = 1, 3), i = 1, 3)
return
end subroutine bsub
Screen output:
0.1000000000000000D+01 0.2000000000000000D+01 0.3000000000000000D+01
0.4000000000000000D+01 0.5000000000000000D+01 0.6000000000000000D+01
0.7000000000000000D+01 0.8000000000000000D+01 0.9000000000000000D+01
0.1000000000000000D+01 0.0000000000000000D+00 0.0000000000000000D+00
0.4000000000000000D+01 0.0000000000000000D+00 0.0000000000000000D+00
0.7000000000000000D+01 0.0000000000000000D+00 0.0000000000000000D+00
Please comment on this... Sure, I can overcome this by a more careful definition of the matrix, e.g. like
subroutine bsub(array, n)
implicit none
real*8, dimension(1:n, 1:n) :: array
orinanother way. But I expected the simple source above towork properly.
grg99
The problem is you explicitly declared "bsub" as "external". If you leave off that declaration then the compiler will complain about a missing definition for "bsub". Then if you define bsub, either by placing it in the same source file, or declaring ti properly in an "interface", then the compiler will be better able to warn you about mismatches like this.
To fix the basic problem, declare bsub as taking a ( : , : )size array. Or as you suggested, pass in the dimensions as a argument.
The compiler can warn you of this coding error if you specify the /gen_interface and /warn:interface options.
t.f90(17) : Error: The storage extent of the dummy argument exceeds that of the
actual argument.
call bsub(a)
Otherwise, the compiler doesn't have the information to connect the two and diagnose the error.
