Memory Bleed
micromuni
I utilize Visual Basic.Net for GUI and either Compaq Visual Fortran 6.6B or Intel Fortran 7.0 for the computations. With both Fortrans, I notice that each time the DLL is called, task manager indicates that the amount of memory used increases by 8K. If I make 20 calls, the program memory size will increase by 160K. What can I do to stop this slight memory bleed?
The bleed is happening on the VB side - nothing that either of the Fortrans can do for you here.
Steve
