Memory / Size used by program
klaus_knebel
Is there a possibility to find out how much memory the fortran program uses whne the program is running.
I do not mean the size of the (.exe) program
I mean the size of memony used when the program is running
Klaus
mecej4
A basic measure is the image size, and that can be obtained at the command line:
C:\ > dumpbin /headers .exe
You can watch the time-dependent memory consumption by locating your application processes in the Task Manager. There are other tools for "process monitoring".
As a program allocates variables on the heap, loads DLLs, and chains calls on the stack, naturally memory consumption is dynamic.
klaus_knebel
Ok thanks
I was hoping, that there is a possibility within the program
Some kind of a compiler option or fortran call or.....
thanks
Klaus
Les_Neilson
Valued Contributor II
You could try looking at GlobalMemoryStatusEX
for example something like :
[bash]module memory_System
   implicit none
   private
   ! Parameters
   ! Used to return data in Mb (ie divide by (1024 * 1024))
   real*8, parameter :: m_dbDivide = 1024 * 1024;
   ! Variables
   integer*4, public :: m_dwMemLength
   integer*4, public :: m_dwMemLoad
   real*8,    public :: m_dbMemTotalPhys
   real*8,    public :: m_dbMemAvailPhys
   real*8,    public :: m_dbMemTotalPageFile
   real*8,    public :: m_dbMemAvailPageFile
   real*8,    public :: m_dbMemTotalVirtual
   real*8,    public :: m_dbMemAvailVirtual
   ! Subroutines
   public:: GetMemoryStats
   contains
! Subroutines
   subroutine GetMemoryStats()
   use kernel32
   IMPLICIT NONE
   type(T_MEMORYSTATUSEX) lpMstMemStat
   lpMstMemStat.dwLength = sizeof(lpMstMemStat)
   if (GlobalMemoryStatusEx(lpMstMemStat)==0) then
      !error
      m_dwMemLength        =  0
      m_dwMemLoad          =  0
      m_dbMemTotalPhys     = 0.0
      m_dbMemAvailPhys     = 0.0
      m_dbMemTotalPageFile = 0.0
      m_dbMemAvailPageFile = 0.0
      m_dbMemTotalVirtual  = 0.0
      m_dbMemAvailVirtual  = 0.0
   else
      m_dwMemLength        = lpMstMemStat.dwLength
      m_dwMemLoad          = lpMstMemStat.dwMemoryLoad
      m_dbMemTotalPhys     = fnUlltoR8(lpMstMemStat.ullTotalPhys)     / m_dbDivide
      m_dbMemAvailPhys     = fnUlltoR8(lpMstMemStat.ullAvailPhys)     / m_dbDivide
      m_dbMemTotalPageFile = fnUlltoR8(lpMstMemStat.ullTotalPageFile) / m_dbDivide
      m_dbMemAvailPageFile = fnUlltoR8(lpMstMemStat.ullAvailPageFile) / m_dbDivide
      m_dbMemTotalVirtual  = fnUlltoR8(lpMstMemStat.ullTotalVirtual)  / m_dbDivide
      m_dbMemAvailVirtual  = fnUlltoR8(lpMstMemStat.ullAvailVirtual)  / m_dbDivide
   end if
   return
   end subroutine GetMemoryStats
real*8 function fnUlltoR8(nIn) use ifwinty implicit none type(T_LARGE_INTEGERX), intent(in) :: nIn integer*8 nI8 integer*4 nBits integer*8 nLow, nHigh !----------------------------------------------------------------------| nbits = 0 !do low if (nIn.LowPart < 0) then nBits = bit_size(nIn.LowPart) nLow = (int8(nIn.LowPart) + 2_8**nBits) else nLow = nIn.LowPart endif !do high if (nIn.HighPart < 0) then nBits = bit_size(nIn.HighPart) nHigh = (int8(nIn.HighPart) + 2_8**nBits) else nHigh = nIn.HighPart endif !combine the data nHigh=ISHFT(nHigh,32_8) nI8=nHigh+nLow fnUlltoR8=nI8 end function fnUlltoR8 [/bash]
end module memory_System
Hope this helps
forgot the function to return the number
Les
Les_Neilson
Sorry I'm not sure how the
 and
stuff got there. I was trying to add in a function I had missed out in my cut and paste. Just ignore those lines.
Les
jimdempseyatthecove
There are multiple issues at play here (to find out how much memory the fortran program uses whne the program is running).
There is the issue of the memory requirements for the code plus static data, plus stack data, plus allocated memory.
Then there is the issue of memory footprint which includes the above plus voids (previously allocated but now returned memory).
The memory foot print is effectively the Virtual Memory requirements of the application. (think of this as "squatting" memory).
The former requirement (sans voids) would be your "working" memory.
Les's suggestion as well as using other heap walk (diagnostic debug routines) can be used to determine heap size and allocations.
It is not unusual for some applications to experience Virtual Memory creap while having a relatively steady working memory requirement (consistantly fragmenting the heap).
Jim Dempsey
