29656 Discussions
Memory access problem with ancient code
dwarning
I try to restore an old legacy code from the 70th. I know it is not standard conform anymore.
The strong reduced shown code, compiled with ifx -g -O0 test_entry.for -o test_entry
brings an memory access violation in line 33. From gdb I got:
Program received signal SIGSEGV, Segmentation fault.
0x00000000004054aa in me$laslas_ (khh=..., mhh=<optimized out>, das=<optimized out>,
    ix=<optimized out>) at test_entry.for:33
33	         Ix = n/2
Same result for gfortran: Variable Ix can't accessed.
Is it possible to fix the problem by compiler switches or different declarations without to change the entire program structure, e.g. splitting the multiple entry subroutine in separated pieces?
      PROGRAM NAP2
      CALL FILIN
      END
      SUBROUTINE filin
      CALL lasa
      CALL name('* Q*. ',3,*52,*46)
 46   CONTINUE
 52   CONTINUE
      END
      SUBROUTINE laslas(Khh,Mhh,Das,Ix)
      IMPLICIT REAL*8(A-H,O-Z)
      INTEGER*2 Khh(Mhh)
      INTEGER Mhh, Ix
      REAL*8 Das
      ENTRY lasa
      RETURN
      ENTRY name(Khh,Mhh,*,*)
      n = 2
      IF ( n.LE.8 ) THEN
         Ix = n/2
         RETURN 1
      ENDIF
      RETURN 2
      END
JohnNichols
Honored Contributor I
The program will not compile in the latest IFX with the latest VS preview.
See below.  Line 11 throws an error not a code fault.
JohnNichols
Debugging code like this will be a nightmare, if it is more than a few hundred lines, good hunting.
dwarning
Thanks for answering.
My version onlinux is quite new:
ifx version 2025.1.1
And substituting the FILIN subroutine with:
      SUBROUTINE filin
      INTEGER*2 Khh(3)
      CALL lasa
      CALL name(Khh,3,*52,*46)
 46   CONTINUE
 52   CONTINUE
      END
brings same error.
The scope of the declared variables and dummy arguments seems lost in the ENTRY parts.
I aggree that the code is not best practice. gfortran needs extra switch -fallow-argument-mismatch to accept the chars.
andrew_4619
From 40 years of fortranning I have no idea what *52 and *46 as values mean and the compiler thinks the same. What you are asking is that the compiler guess what the non standard interpretation of some code was in an ancient compiler and do the same thing. IMO you have some serious refactoring to do or if that is too much throw it in the bin and go on holiday instead and have some beers. I am sorry I cannot help.
GVautier
New Contributor III
*52 and $46 are labels for alternate return
return 1 returns to label 52
return 2 returns to label 46
It's a legacy fortran standard feature  becoming obsolescent in Fortran 95
https://www.intel.com/content/www/us/en/docs/fortran-compiler/developer-guide-reference/2025-0/alternate-return-arguments.html
JohnNichols
It is not deleted Fortran and IFX did not object.  The real problem is the implicit and the declaration of variables.
If you have the energy, the stultitia and the time, then the first thing is to fix all the variables and discover the numerous errors in variable naming like  name and nane, which may look alright but it not what is intended.
It is very old Fortran and like Old English it can be hard to understand.
    PROGRAM NAP2
    implicit none
    character*7 ACD
    ACD = '* Q*. '
    CALL FILIN(ACD)
    END
    SUBROUTINE filin(ACD)
    implicit none
    integer IX
    character*7 ACD
    Write(*,*)ACD
    CALL lasa(3)
    CALL name(ACD,3,IX,*52,*46)
46  Write(*,*)"At 46"
    return
52  Write(*,*)"At 52"
    return
    END
    IMPLICIT none
    INTEGER*2 Khh(Mhh)
    INTEGER Mhh, Ix
    REAL*8 Das
    character*7 ACD
    integer n
    ENTRY lasa(IX)
    write(*,*)"At lasa", IX
    RETURN
    ENTRY name(ACD,Mhh,IX,*,*)
    write(*,*)"Name"
    n = 2
    IF ( n.LE.8 ) THEN
        Ix = n/2
        RETURN 1
    ENDIF
    RETURN 2
    END
It is not hard to fix, about 20 minutes work, but you have to start with implicit none and if you call name, then if you do not pass IX to name it cannot see it, and no I do not know why, I just write the code I am not Steve.
JohnNichols
In the Filipino language, "laslas" primarily means "to cut" or "to slash," often referring to a deep cut made with a sharp object. It can also be used more metaphorically to describe budget cuts or other "cuts" in a broader sense. The word originates from the root "las," implying a cut or incision.
andrew_4619
Yes now you mention alternative return I have seen that, but the problems with this code run deeper. I guess when you write a new compiler from scratch mixes of non standard and obsolete code are more likely to fall through holes in testing and will not be a high priority in the allocation of resources for fixing things. As noted below is seems strange that some things ever compiled ok but I have seen many examples of code errors that worked because the compiler did not see the error and the result happened to be what the coder expected so it was deemed good code. Without validated results from the old compiler it can be hard to fix.
GVautier
New Contributor III
The problem is to know if that code has ever been successfully compiled in that state.
For me the sentence
is invalid because ix is not referenced in arguments so where can the compiler returns the value?
JohnNichols
if I do not put IX in the arguments, then line 43 cannot see the IX declared in the subroutine at the subroutine level and it crashes.
From my write statements it appears to run ok.
No one has written code like this since the 1970s, but knowing how to fix it is important,  I actually think the return1 etc is neat.
dwarning
@JohnNicholsthank you. Yes include IX in the argument list of name() makes the trick. I will try it but I am afraid that there a lot of further variables to consider. Because my test case is only a reduced excerpt.
It is curious for me that IX is not seen in ENTRY name() even it is declared in the subroutine.
Perhaps is split the code in separate subroutines.
JohnNichols
@andrew_4619 , it is unlikely that anyone would use this code unless it was unique and the cost to create from new was higher than a fix.
Sometimes it is better to fix the old, where it is a rare bit of code, it is short and the need is high. Usually the code is sitting in some thesis and it has not been used past the research.  @mecej4  helped me wonderfully with Harrison's 72 code, I learnt a lot of useful things to drive structural reliability analysis forward.  We have not heard from him in six months, I hope he is ok.
Without doubt the best FEM code is ULARC, but it is for special structural uses, but for those at the leading bleeding edge of the reliability analysis you cannot find better or equivalent.
The 1960's team at UCB were really good in structures, their Drain program has been an academic favourite for years, it is just limited.  There is no duplicate to Powell's group anywhere in structures.
I was standing on a major bridge over the Mississippi River discussing the Ularc analysis with a state engineer,  when you need good code you really need it.
I have about 100 million database records from accelerometers in several mySQL tables.  I thought I had trapped in code all of the versions that the date and time could take as output from mysql and I just found a new one, after 8 years.
Fortran is fun, because it is fast and this forum is the best.
GVautier
New Contributor III
From the documentation :
"There can be any number of alternate returns in a subroutine argument list, and they can be in any position in the list."
So the position of IX is not relevant.
Effectively, the old compilers often fail to detect coding errors unlike newer ones but produce apparently functional programs.
But before all, correct the test code by adding Ix in name entry and call.
      CALL name('* Q*. ',3,Ix,*52,*46)
      ENTRY name(ACD,Mhh,Ix,*,*)
JohnNichols
There is no relevance to any of the positions as long as there is a 1 to 1 correspondence in name call and subroutine or entry
But Fortran cannot see a variable passed in the subroutine after the entry statement, so you may as well have separate subroutines.
This is the beauty of Lisp, you start out with built in commands that are a strange language and then you write programs that are almost plain English and easy to follow, unless you like to make it difficult to read and debug.
An example of a program that is easy to write is a Hardy Cross - pipe analysis program, it is very hard to scale, almost impossible actually, but it is theoretically sound.  But saying the code is correct at scale is impossible as you cannot get solutions that converge in a reasonable time.  I know I have tried.
dwarning
Found this fruitful discussion here:
Runtime-issues-in-legacy-multiple-entry-subroutines
Because the argument list extension would be too large, I want try to transfer the these variables per common block.
Thank you to all!
JohnNichols
There is one really great programmer on this forum, the discussion you showed had the best explanations from @mecej4 , there are also great programmers, but he is the best.  Personal opinion and I am poor programmer.
I am sure that he would tell you that common blocks are a big no.
We see common blocks slipping back into c# and it is annoying.  With another name, but an apple in the UK and apfel in Germany  is still mainly red and good for you, not so common blocks.
Use types as @mecej4 showed me for old code from the 70's.  I include samples. It is worth the effort.
    !   Real variables
    REAL                time(2)         !   Holds the numbers for the run time calculation
    !   Type variables  model holds the overall model data and Triangle holds data for each triangular element
    TYPE (Model),       TARGET :: ModelA                            !   Model for the FEM
    TYPE (Triangle),    allocatable,   TARGET :: sTriShells(:)      !   Each triangle that makes up the FEM model
    TYPE (sbeam),       allocatable,   TARGET :: sBeams(:)
    TYPE (aBeam),       allocatable,   TARGET :: saBeams(:)      !   Each triangle that makes up the FEM model
    !   Routine opens the files used for data input and output
    !   Base is the ultimate lowest module to allocate the file numbers, si, sw, sa, slog
    call Files(1)
    !call OpenFiles(si,sw,sa,slog,srA)                  Not used at this stage
    !   Saves the start time for the analysis time estimate
    CALL cpu_time(time(1))
    !   Set up the model type used to hold the main details of the overall model
    Call SetModel(ModelA, Triangles, BeamNum)
    !   Allocate memory for the triangular elements
    ALLOCATE (sTriShells(Triangles), ModelA%indexM(3,ModelA%MaxNodeNumber), ModelA%nodes(ModelA%MaxNodeNumber),ModelA%offsetnodes(ModelA%MaxNodeNumber),ModelA%nodeloads(ModelA%MaxNodeNumber,6), ModelA%nodeWeight(ModelA%MaxNodeNumber),sBeams(NTA), saBeams(Beamnum), STAT=astat)
    IF (astat.NE.0) then
        STOP 'Could not allocate Shells or Model'
    endif
    Beams = Zero
    CAll ReadBeams(Beams, sBeams, Triangles)
    ModelA%SK = ZERO               !   Zero the Stiffness Matrix
    ModelA%nodes = -1               !   Set the node numbers to -1 so they can be counted
    ModelA%nodeloads = ZERO
    !   Read in the data for each triangular element from the si input file
    Do I = 1,Triangles
        Call Read_Triangles(sTrishells(I))
        call setRestraints(sTrishells(I)%restraint, sTrishells(I)%nodes, ModelA%nodes)
    end do
    Do I = 1, Beamnum
        call Read_Beams(saBeams(I), sBeams, I)
        call setRestraintsB(saBeams(I)%restraint, saBeams(I)%nodes, ModelA%nodes)
    end do
    Call CountNodes(ModelA%nodes, ModelA%N, ModelA%NodeCount, ModelA%MaxNodeNumber,ModelA%LoadedNodes, ModelA%nodeloads)
    ALLOCATE (ModelA%SK(ModelA%N,ModelA%N),ModelA%XF(ModelA%N),ModelA%LoadXYZ(ModelA%N), ModelA%nodemass(ModelA%N,ModelA%N),STAT=astat)
        STOP 'Could not allocate SK or XF'
    endif
    ModelA%SK = ZERO
    Call SetLoad(ModelA%nodeloads,ModelA%loadxyz, ModelA%nodes, ModelA%MaxNodeNumber,ModelA%N)
jimdempseyatthecove
I would suggest that you use a module instead of common block.
The use of common block may present issues down the road (name collisions and/or omission of variable names/types).
Jim Dempsey
