Memory leak: a minimal example
mchoi
I have found that a constantly deallocated memory at the end of the subroutine (or even the program). I am wondering if I made anything wrong here. I suppose that all allocated memories must be deallocated at the end. But the diagnostic tool tells me 'Allocations (diff)' is still +5 at the end. The example code is attached.
Thank you.
Steve_Lionel
I am not seeing a problem here, and your description seems strange.
The memory you allocate with ALLOCATE is completely deallocated by the DEALLOCATE. There is additional memory that has been allocated for the I/O operations - those are not explicitly deallocated by the program but go away when the process exits.
In the screenshot below, I did a snapshot before and after the ALLOCATE and before and after the DEALLOCATE.
I then removed the PRINT and saw this:
Looks perfectly normal to me.
jdelia1
Try: (i) containing the subroutine within the main program, (ii) using a module. For example, in the first case,
program leak_test
    implicit none
    double precision, allocatable :: mat(:,:)
    integer :: i
    allocate (mat(100, 100))
    do i = 1, 100000
        call sub_calc(mat)
        if (mod(i, 1000) == 0) print *, "iteration: ", i
    end do
    deallocate(mat)
    contains
    subroutine sub_calc(a)
        implicit none
        double precision :: a(1000, 1000)
        a(1,1) = a(1,1) + 1.0d0
    end subroutine sub_calc
end program leak_test
Then,
$ ifx --version
ifx (IFX) 2025.3.3 20260319
Copyright (C) 1985-2026 Intel Corporation. All rights reserved.
$ ifx -mtune=generic -std18 -WB -warn all -check all -o testcase-0222-ifx.exe testcase-0222.f90
$ testcase-0222-ifx.exe
iteration: 1000
iteration: 2000
iteration: 98000
iteration: 99000
iteration: 100000
Jorge D'Elia
Thank you.
jdelia1
Try: (i) using a module; (ii) containing the subroutine within the main program. For example, in the second case:
program leak_test
    implicit none
    integer :: i
    do i = 1, 100000
    call sub_calc(mat)
    end do
    deallocate(mat)
contains
        implicit none
$ ifx --version
iteration: 1000
iteration: 2000
iteration: 99000
iteration: 100000
Regards.
Jorge.
Steve_Lionel
mchoi
Thank you. Yes, here, after removing the PRINT, I have no more additional memory allocation. It is now +0 in total.
