29487 Discussions
Memory leak with WRITE operation on an internal file (variable of CHARACTER type)
FortranFan
Consider the following trivially simple program :
PROGRAM p
   IMPLICIT NONE
   !.. Local variables
   CHARACTER(LEN=2) :: StrBuffer
   INTEGER :: I
   I = 1
   WRITE(StrBuffer, FMT='(I2)') I
   STOP
END PROGRAM p
When the code is compiled with Intel Fortran (version 14 or 2015 Beta) and the program is executed, Dr Memory utility indicates there is a memory leak associated with the WRITE statement.  The output generated by the utility is as follows:
         Dr. Memory version 1.7.0
         Running "Debug\TestFor32.exe"
         Error #1: LEAK 12 bytes
         replace_malloc
             d:\drmemory_package\common\alloc_replace.c(2320):
         for__get_vm
             ??:0
         for__acquire_lun
             ??:0
         for_write_int_fmt
             ??:0
         P
             TestFor.f90(10):
         main
             ??:0
         ERRORS FOUND:
               0 unique,     0 total unaddressable access(es)
               0 unique,     0 total uninitialized access(es)
               0 unique,     0 total invalid heap argument(s)
               0 unique,     0 total GDI usage error(s)
               0 unique,     0 total handle leak(s)
               0 unique,     0 total warning(s)
               1 unique,     1 total,     12 byte(s) of leak(s)
               0 unique,     0 total,      0 byte(s) of possible leak(s)
         Details: C:\..\DrMemory-TestFor32.exe.4680.000\results.txt
Can someone at Intel please investigate and provide feedback on this memory leak?  In one of my codes, such a WRITE operation on an internal file can occur many times and there are some performance issues with this code, hence I appreciate any clarification any one can provide.
FortranFan
FWIW, when the above example is compiled and executed with gfortran 4.9, one gets the following:
Dr. Memory version 1.7.0 build 5 built on Apr  4 2014 23:38:05
Dr. Memory results for pid 1652: "TestFor.exe"
Application cmdline: "Debug\GNU\TestFor.exe -show_reachable"
FINAL SUMMARY:
DUPLICATE ERROR COUNTS:
SUPPRESSIONS USED:
NO ERRORS FOUND:
      0 unique,     0 total,      0 byte(s) of leak(s)
Details: C:\..\DrMemory-TestFor.exe.1652.000\results.txt
Yep, we know about this one and recently fixed it. The fix should be in the final 15.0 release.
FortranFan
Excellent, thanks!
