Message Board Word Wrap
wkramer
I notice that if I edit a message on this board, the width of the message window adjusts itself to prevent word wrapping.
How can I avoid this?
Walter Kramer
This happens if you have a "code" element in your message with a long line. Note that viewing the original also stretches the margin. Code boxes don't wrap (nor should they).
wkramer
What about this message then?
When I first enteredmy reply everyting was OK, but after editing it the window was stretched (or perhaps you don't see it stretched?).
Walter
I do see it stretched, and there may be a bug in the way the forum treats a code section on editing. I'll ask.
send_to_alan
Hi i seem to have come across this bug on other boards as well. If you use a very high resolution display (eg mine is a 1400*1050) it can cause the very long lines.(though it should not) Walter are you using a 1600*1200 display(perhaps dell) laptop by any chance!!
it is something to do with the line breaks.
wkramer
No, I am using an ordinary CRT screen with 1024*768 resolution.
Walter
