I want to use MessageBox from a dilog box routine in a win32 application. It seems I need the handle of thedialog box.as an argument of the MessageBox function. How do I get thei handle?
I am a CVF user and am new to this forum. I will now start reading all of the postings. Thanx for any help you can give.
LongThong
Yes. NULL works fine.Thank you. But the message box is beneath the main frame window. I have to minimize the main window to see it and respond. I wonder what I am doing wrong?. I never had this problem with QuickWin.
LongThong
Use Dlg%hWnd (preferred) or GetForegroundWindow instead.
I discovered what I was doing wrong. I wasn't handling the WM_PAINT message. When I put some code in the handler everything came out in the correct order. Sorry to have bothered you. NULL workd fine. Thanx again.
LongThong
