29648 Discussions
Microsoft Visual Studio 2005 Premier Partner Edition
tracy_MM
I need Intel Fortran 11.0.061 for compiling a software. There is no errors while running the install and it seems to install along with (with Microsoft Visual Studio 2005 Premier Partner Edition*) which I can see in the control panel, While running checks with compiling software ( Fortran Medic Utility ) to test if intel Fortran 11 is installed it fails with the following error that visual studio vs2005 does not appear to be installed. Running Windows 10 1809 version on a domain joined machine, Tested on fresh install same error while running checks
Thank you in advance,
Tracy
Steve_Lionel
VS2005 isn't supported on Windows 10.  Nor Windows 7. Microsoft at one time had an article explaining how to get it to work on Windows Vista - required you to run it as Administrator.
You don't "need" that ancient version of Intel Fortran. Use a current version.
