29383 Discussions
Miscompilation when passing real or imaginary of a complex array
WiserOrb
Ifx miscopiles when passing the real or complex part of an explicit shape array to a procedure
Ifort instead provides the expected output
Notice that I have specified the intent(in)
When i specify any other intent ifx crashes
main.f90
program main
  complex :: x(3)
  x(1)%re = 1
  x(2)%re = 2
  x(3)%re = 3
  x(1)%im = 4
  x(2)%im = 5
  x(3)%im = 6
  write(*,*) x
  call foo(x%re)
  call foo(x%im)
  contains
  subroutine foo(x)
    real, intent(in) :: x(3)
    write(*,*) "x", x
  end subroutine
end program
ifx main.f90; ./a.out
(1.000000,4.000000) (2.000000,5.000000) (3.000000,6.000000)
 x   1.000000       4.000000       2.000000
ifort instead provides the correct output
ifort main.f90; ./a.out
 x   1.000000       2.000000       3.000000
 x   4.000000       5.000000       6.000000
ifx crash without specifying intent(in):
main.f90(1): error #5623: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report.  Note: File and line given may not be explicit cause of this error.
program main
compilation aborted for main.f90 (code 3)
Devorah_H_Intel
The fix for this issue will be included in the future 2025 ifx
$  ifx f10.f90 -o f10 -what && ./f10
 Intel(R) Fortran xxxxxxx
rory586
main.f90
program main
  complex :: x(3)
  x(1)%re = 1
  x(2)%re = 2
  x(3)%re = 3
  x(1)%im = 4
  x(2)%im = 5
  x(3)%im = 6
  write(*,*) x
  call foo(x%re)
  call foo(x%im)
  contains
  subroutine foo(x)
    write(*,*) "x", x
  end subroutine
end program
program main
Something's wrong with your computer program.
It's like trying to put together a puzzle with missing pieces. Let's figure out how to fix it.
WiserOrb
I believe ifx doesn't pass the correct stride to the subroutine.
If we assume ifx packs complex numbers with alternating real and imaginary part the x vector has flat an in memory representation:
[1, 4, 2, 5, 3, 6]
When I pass the real part of the array, ifx should pass an array with stride 2 starting from the first entry of the array
[1, _, 2, _, 3, _]
However i think ifx is setting the stride to one, so the subroutine sees:
[1, 4, 2]
Then there is the compiler crash when I'm not specifying `intent(in)` in the subroutine, but I cant debug it without access to the ifx source code
Devorah_H_Intel
Thank you for reporting this to us. I have escalated this issue to our compiler engineering team.
Devorah_H_Intel
