Missing Compile Warning (I think)
jackosullivan
Does IVF no longer catch the use of a variable before it is defined?
If I recall correctly, when using CVF6.6 in MS Developers Studio and IVF 8+ in MSVS.NET2003, I could force warnings to be treated as errors, and the compilerwouldkeep me from trying to use a variable before I defined it. Even though this did not work well with variables in COMMON, this was a marvelous way to catch misspellings.
Now, with 9.1.3663.2003 in MSVS.NET 2003 SP1, I've been a several-day victim of its missing at least one such screw-up that was not associated with a COMMON.
Is this option no longer available? Or have I missed one of the better-hidden options in the Project Properties?
Or is it perhaps fixed in IVF10?
Thanks and God bless!
Jack
In Intel Fortran, uninitialized variable checking is done at run-time and not compile time. It is an optional setting in Visual Studio under "Run-Time". The class of things it will pick up is different from CVF due to different compiler technologies being used.
However, you should also try the new Static Verifier option in 10.0 - it will catch a lot of things CVF did and more.
jackosullivan
Thanks, Steve, for the speedy and as usual right-to-the-point answer(s).
Looks like you just tipped me over the edge into the IVF10 bin ... despite it being mid-project.
Thanks again and God bless!
jack
