Missing FFTW libraries
Leonardo_A_
I'm trying to compile a code written in fortran90/95 and I'm getting this error:
user:~> make
ifort -O3 -lmpi -L/opt/local/intel/fftw/lib -I/opt/local/intel/fftw/include - I/opt/sgi/mpt/mpt-2.03/include -L/opt/sgi/mpt/mpt-2.03/lib -o /test module_param.o incompact3d.o mesure.o schemas.o derive.o spectral.o tools.o filtre.o parametre.o forcage.o navier.o convdiff.o viv.o slfft3d_shift.o poisson.o
slfft3d_shift.o: In function 'slfft3d_shift_':
slfft3d_shift.f90:(.text+0x587e): undefined reference to 'rfftw3d_f77_mpi_create_plan_'
slfft3d_shift.f90:(.text+0x58a3): undefined reference to 'rfftwnd_f77_mpi_local_sizes_'
slfft3d_shift.f90:(.text+0x58cd): undefined reference to 'rfftwnd_f77_mpi_'
slfft3d_shift.f90:(.text+0x58d9): undefined reference to 'rfftwnd_f77_mpi_destroy_plan_'
slfft3d_shift.f90:(.text+0x91ca): undefined reference to 'rfftw3d_f77_mpi_create_plan_'
slfft3d_shift.f90:(.text+0x91ef): undefined reference to 'rfftwnd_f77_mpi_local_sizes_'
slfft3d_shift.f90:(.text+0x9219): undefined reference to 'rfftwnd_f77_mpi_'
slfft3d_shift.f90:(.text+0x9225): undefined reference to 'rfftwnd_f77_mpi_destroy_plan_'
slfft3d_shift.f90:(.text+0x111e7): undefined reference to 'rfftwnd_f77_one_real_to_complex_'
make: *** [/test] Error 1
Here's the Makefile:
FC = ifort
OPTFC = -O3 -lmpi -L/opt/local/intel/fftw/lib -I/opt/local/intel/fftw/include - I/opt/sgi/mpt/mpt-2.03/include -L/opt/sgi/mpt/mpt-2.03/lib/test : module_param.o incompact3d.o mesure.o schemas.o derive.o spectral.o tools.o poisson.o filtre.o parametre.o slfft3d_shift.o forcage.o navier.o convdiff.o viv.o
$(FC) $(OPTFC) -o /test module_param.o incompact3d.o mesure.o schemas.o derive.o spectral.o tools.o filtre.o parametre.o forcage.o navier.o convdiff.o viv.o slfft3d_shift.o poisson.o
module_param.o : module_param.f90
$(FC) $(OPTFC) -c module_param.f90 incompact3d.o : incompact3d.f90
$(FC) $(OPTFC) -c incompact3d.f90 mesure.o : mesure.f90
$(FC) $(OPTFC) -c mesure.f90 spectral.o : spectral.f90
$(FC) $(OPTFC) -c spectral.f90 schemas.o : schemas.f90
$(FC) $(OPTFC) -c schemas.f90 derive.o : derive.f90
$(FC) $(OPTFC) -c derive.f90 tools.o : tools.f90
$(FC) $(OPTFC) -c tools.f90 forcage.o : forcage.f90
$(FC) $(OPTFC) -c forcage.f90 navier.o : navier.f90
$(FC) $(OPTFC) -c navier.f90 filtre.o : filtre.f90
$(FC) $(OPTFC) -c filtre.f90 parametre.o : parametre.f90
$(FC) $(OPTFC) -c parametre.f90 convdiff.o : convdiff.f90
$(FC) $(OPTFC) -c convdiff.f90 poisson.o : poisson.f90
$(FC) $(OPTFC) -c poisson.f90 slfft3d_shift.o : slfft3d_shift.f90
$(FC) $(OPTFC) -c slfft3d_shift.f90 viv.o : viv.f90
$(FC) $(OPTFC) -c viv.f90
When I include the libraries required in the Makefile I get the following message:
user:~/test> make
ifort -O3 -lmpi -I/opt/local/intel/fftw/include -L/opt/local/gnu/fftw - I/opt/sgi/mpt/mpt-2.03/include -L/opt/sgi/mpt/mpt-2.03/lib -I/opt/fftw/2.1.5.1/cnos/include -L/opt/intel/composerxe-2011.0.084/mkl/include/fftw/fftw_f77.i -L/opt/fftw/2.1.5.1/cnos/lib -I/opt/local/intel/fftw -I/opt/fftw/3.1.1/cnos/include -L/opt/fftw/3.1.1/cnos/lib - I/usr/local/packages/nag/p3dfft-single/2.3/include -L/usr/local/packages/nag/p3dfft- single/2.3/lib -o /home/u/guitar88/bin/teste module_param.o incompact3d.o mesure.o schemas.o derive.o spectral.o tools.o filtre.o \
parametre.o forcage.o navier.o convdiff.o viv.o slfft3d_shift.o poisson.o -lm -L/opt/local/intel/fftw/lib -lsrfftw_mpi \
-lsrfftw -lsfftw_mpi -lsfftw
ld: cannot find -lsrfftw_mpi
I'm using ifort compiler and I'm on a supercomputer environment working with MPI. Please, any clue of what is going on? Cheers.
TimP
I would be concerned about compatibility between any fft libraries which use MPI and your mpt, and whether you may be mixing Intel MKL fftw with one or more other versions present on your system.  "supercomputer environment" is far too vague, but I suppose SGI  should be able to give better answers about their expectations for linking fftw.  Among the Intel forums, the MKL forum is more likely to find an expert on this topic.  If you are depending on Intel references, you should be checking the MKL link advisor against what you have (but you would need to determine the answer about MPI version compatibility).  I would be concerned that a "gnu" fftw library would be more likely to be compatible with gfortran than with ifort, and about your searching at least 2 different trees for your fftw.
