Mix language problem
Zhanghong_T_
Hi all,
I am trying to create a project which includes both Fortran and C++ source files with Fortran main file. However, When compiling the project, these C++ files are not compiled, which in turn leads to compile error: unresolved external symbol XXX referenced in function _MAIN__
I have successfully tested when build the C++ source code as a static library and include the library into the Fortran project. However, I wish to debug the program into C++ code.
Could anyone tell me how to do? or give me a simple example project in which the Fortran code call C++ code?
Zhanghong Tang
In VS.NET, Fortran and C code has to be in separate projects. But debugging should not be a problem - just make sure that the C++ code is built with the debug options and you should be able to step into or set breakpoints in the C++ code.
Zhanghong_T_
Hi Steve,
Thank you very much! I have also noticed this.
Zhanghong Tang
