29393 Discussions
Mixed Language issue (Accessing C structure from Fortran)
nitinshukla
I have to access a C structure from Fortran using COMMON BLOCK. In my C program the structure's variable is shared for multiple process access using the #pragma directives. On the Fortran side I have defined a COMMON BLOCK to map on this C structure variable. I am trying to compile the code to build the DLL. The problem I face is the Linker gives me error as stating 'one or more multiply defined symbols found' for the structure variable declared. My code looks like this.
Code:
*********************** C code *************************
###### globalParams.h ########
#pragma pack(2)
	typedef struct CPPDLL_MACRO _GlobalParam {
		int k[2];
		float var;
		int l;
		char str[11];
	} GlobalParam;
#pragma pack()
	extern CPPDLL_MACRO GlobalParam globalParam;
###### globalParams.c ######
#pragma data_seg (".shared")
	GlobalParam globalParam = {0};
#pragma data_seg()
#pragma comment(linker, "/section:.shared,RWS")
******************** Fortran code *************************
###### Engine.FI #####
!DEC$ ATTRIBUTES ALIAS:'_globalParam' :: GLOBALPARAM
	COMMON /GLOBALPARAM/ K(2), VAR, L, STR
	INTEGER*4    K, L
	REAL*4       VAR
	CHARACTER*11 STR
###### INITIALIZEPARAMS.F ######
	SUBROUTINE INITIALIZEPARAMS
#include "Engine.FI"
	DATA K   / 5, 8 /
	DATA VAR / 2.30000 /
	DATA L   / 9 /
	DATA STR / "HELLO WORLD" /
	END SUBROUTINE
I am trying to compile the above code to build a DLL but the linker gives me the following error.
Code:
Linking...
INITIALIZEPARAMS.OBJ : error LNK2005: _globalParam already defined in globalParameters.obj
INITIALIZEPARAMS.OBJ : warning LNK4006: _globalParam already defined in globalParameters.obj; second definition ignored
   Creating library Debug/CPPDLL.lib and object Debug/CPPDLL.exp
..inCPPDLL.dll : fatal error LNK1169: one or more multiply defined symbols found
Error executing link.exe.
CPPDLL.dll - 2 error(s), 1 warning(s)
Can any one help me resolve this problem? Why is the Fortran COMMON BLOCK 'GLOBALPARAM' not mapping to the memory location of 'globalParam' structure defined in the C code?
Any help will be obliged. I am using CVF 6.6 and VC++ 6.0.
Nitin
Message Edited by nitinshukla on 02-28-2005 02:05 AM
TimP
The globalParam objects defined in C and in Fortran should be duplicates. The linker is correct in telling you to use just one of them.
Steven_L_Intel1
In case Tim's use of the term "defined" is ambiguous, try "initialized". You can't initialize global storage (common) in more than one program unit.
nitinshukla
Hi sblionel,
Thanks for the clearing the ambiguity. As you now understand what I am trying to achieve here, can you let me know how I can go about it. I want tokeep the global variable globalParam in a shared section of DLL inorder to share it across processes while at the same time want to intialize this parameterin Fortran. Is there a way to do this? Any help is obliged. Thanks.
Nitin
Steven_L_Intel1
Remove the " = {0}" from GlobalParams.c is I think what you need. I am not a C expert.
However, I am not sure this will work properly because Fortran will want to put the COMMON in the .data section. You may need to use a linker /section switch to specify RWS since Fortran does not have a directive to do this. In this case, remove GlobalParams.c entirely and use the linker switch.
Message Edited by sblionel on 03-01-2005 08:34 AM
nitinshukla
Hi sblionel,
Thanks. You have been of great help. I tried the approach of sharing the .data section using the linker /section switch to specify RWS. But the linker gives warning LNK4092.It leads to the issues of relocation.
I thinkit will be better if the COMMON BLOCK data is directed to some user specfied section rather than .data. Thenuser defined section can be shared using same linker /section switch. This willspare mefrom sharing.data section from the DLL. I do not knowhow can I direct theCOMMON BLOCK data to user specified section in DLLusing FORTRAN. I know how to do this in C but don't know howCVF handles this.
Nitin
Message Edited by nitinshukla on 03-01-2005 09:41 PM
Steven_L_Intel1
There is no support in CVF for specifying the name of the data section for a common. See the SAMPLESDLLDLLEXP2 examples for an example of creating a write-shared common.
durisinm
Is there going to be a problem mapping C's char str[11] to Fortran's CHARACTER*11 STR? Doesn't Fortran pass a hidden string length variable before or after the string data?
Mike D.
