29649 Discussions
Mixed language problem Fortran calling C++
DavidWhite
Valued Contributor II
I am a complete novice as far as C++ is concerned, so having great difficulty with interfacing my Fortran and C++ codes:
On the Fortran side:
 INTERFACE
    SUBROUTINE HASHSTRING (str_in, str_in_len, str_out, str_out_len, Status) BIND(C)
    USE,INTRINSIC :: ISO_C_BINDING  ! Declares C kinds
    USE IFWIN, ONLY : DWORD
    CHARACTER(KIND=C_CHAR),DIMENSION(*) :: str_in,str_out
    INTEGER(C_INT), VALUE, INTENT(IN) :: str_in_len, str_out_len
    INTEGER(DWORD), INTENT(INOUT) :: Status
    END SUBROUTINE HASHSTRING
END INTERFACE
On the C++
extern "C" void hashstring (
    char* MyString,
    int MyStringLen,
    char* encHash,
    int encHasHLen,
    DWORD dwStatus)
Everything is working except returning the Status.  Even though when in debug mode, this has a value of 0 in the cpp routine, when I get back to Fortran, it has the value it had before the call.
SOLVED it myself -- needed & on the dwStatus argument.
David
