Mixed random number problem
z_wang
Dear Steve,
Thank you very much for the reply.
I have another question about random generator. Since the standard normal distribution generator only appears in IMSL, while the uniform distribution by RAND_NUMBER(..) is an intrinsic function. If both of these two kind random number is needed, is it a good style to mix them in the codes? If yes, should I set their seeds separately?
Thank you for your consideration.
James
If you need both kinds of generators, there's no problem at all using them both. The seeds need to be set separately, as I indicated in the other topic. The IMSL routines do not know about RANDOM_SEED.
