Module removes stack overflow error
ymahmoudi
Dear f 90 programmers
I run a simple code to solve 2-d heat equation using OPENMP
for array size more than (301*301) i got stack overflow error and the code has terminated. But as i defined variables in "MODULE" i got no error. Can anyone explain whay this is for??
Module variables are global and statically allocated. If you have local arrays, they will be allocated on the stack, which is good for threading but bad for stack usage. I'd suggest making these ALLOCATABLE arrays and allocating them to the proper size, or increase the stacksize of the application. Static arrays can introduce threading errors.
TimP
You may have shifted some of your big arrays from local (default stack) allocation to global heap allocation. When you set /Qopenmp, implying /Qauto, if you don't set heap-arrays, the local arrays have to go on stack, as the compiler doesn't know whether they will be replicated for each thread. This use of MODULE may be a good strategy, to keep shared data off the stack.
ymahmoudi
Deat Steve
Thanks for reply. Actually i'm so engage with stack overflow error inexecuting my code regarding to what i gonna do in my Ph.d thesis. My main code containsdiffetent variables which defined in common block and most of them are shared between different subroutines. when i run the code in sequential mode i got no error but with OPENMP igot stack overflow and i have to decrease the grid size. may you please tell me what can i do to remove the stack error, in additioni cant define array in allocating mode bacausethe arrays shoulb be share between different program units.
ymahmoudi
Quoting - tim18
Thanks for reply
May you please tell me, how can i use heap-array tocompile a program on intel windows?Inlinux adding this option to command line willdo this, but i don't know whatto doin windows.
TimP
Quoting - ymahmoudi
I suppose (could be missing something) it's not one of the Properties options, so it would have to be added as additional command line option e.g. /heap-arrays:512
The property is Fortran > Optiimization > Heap Arrays. Set it to 0.
ymahmoudi
In command line i typed /heap_arrays, but i didn't work and i still get stack overflow, in addition in property>Optimization i can't find the option 'heap-array'? please help me with this
Which compiler version are you using?
