Module variable not recognised in debugger
Anthony_Richards
I want to look at a module variable, so following the documented technique for doing this, in the Watch window I type
MODULENAME::VARIABLENAME
The debugger replies that the variable is not recognised, even though the variable is defined as a PARAMETER in the module and calculations up to that point use its value.
The module is in a separate Fortran file. Is that the problem?
I am using VS 2012 Pro.
Lorri_M_Intel
Ah, a PARAMETER?  When you built the module, did you use the /debug-parameters switch?
By default, parameter names only "live" during the compilation stage, and are not put into the debug symbol table.   The switch above will change that default.
               --Lorri
Anthony_Richards
Thanks, Lorri.
