Moveto top
pmichael
After outputting a bunch (~100 lines) of text to a QWICKWIN window (after SETWINDOWCONFIG(wc)) I would like to scroll to the top so that the user can read the top lines first. I have tried:
CALL MOVETO(int2(1),int2(1),XXYYxy)
and
CALL settextposition(int2(1),int2(1),XXYYrc)
Neither did anything at all! Any suggestions?
james1
Make sure your window has enough buffer lines for your output. For example:
program test ! quickwin
use dflib
implicit none
type (windowconfig) wc
integer i
if (GETWINDOWCONFIG(wc)) then
  wc%numxpixels  = -1
  wc%numypixels  = -1
  wc%numtextrows = 120
  call SETWINDOWCONFIG(wc)
end if
call clearscreen($GCLEARSCREEN)
do i = 1, 100
  print *, "Hello, this is line ", i
end do
pause
end program test
James
pmichael
Sorry for posting such a dumb question!
It was all my fault, I had nadvertently left the folloing statment in my program:
wc.mode = QWIN$SCROLLDOWN
and so, of course, window was scrolled to bottom.
