29649 Discussions
Moving solution to a different drive
ahasan
Icopied an IVF8.1 project/solution tohard drive E, butpressing ctrl+F5 or F5 always executes the code on the original drive, C. The property windowfor the copy on E shows the correct drive and path.
How do Iget the codeon drive E to execute when I press ctrl+F5 or F5?
Thanks for a reply.
The path for execution is in the Debug property page for the project. Normally this is not an absolute path, but I have sometimes received projects set up that way.
ahasan
That worked, thank you.
