29643 Discussions
Multi-dimensional array pointer points to a 1D array?
Yaqi_Wang
I have a a prrety large 1D array allocated. Let us say x(1:100000000). Then I want to use a 2D array pointer y(1:50000000,1:2) to point to x, so I can access array elements in a more meaningful way.
Is there an easy way to do this? I do not want to reallocate memory and copy x to y.
Easy way - pass X(1) to a subroutine where the argument is declared (1:50000000,1:2) and do what you need there. This can also be done with pointer remapping in version 12 but I'll have to do some experiments first. You can also fake it by using C_F_POINTER(C_LOC(X),P,[50000000,2]) where P is a POINTER with dimension (:,:).
Yaqi_Wang
thanks Steve.
Few further questions:
Is the pointer remapping written in Fortran standard?
If I use C_F_POINTER to remap the pointer and later x becomes unaccessable, then can I deallocate memory with ponter Y?
abhimodak
There are a few things that the program below does not test but it looks like pointer remapping is working in IVF 12 update 1.
Abhi
[fxfortran]      Program Test_PointerPartition
            ! Purpose: Test bounds remapping for pointers.
         Implicit None
         Real(8), Target :: A(0:20), C(22:26)
         Real(8), Pointer :: B(:)
         Integer, Target  :: G(100)
         Integer, Pointer :: H(:,:)
         Integer :: i
         A = 1.0d0; C = 0.0d0
         Nullify(B)
         B => A(11:20)
         print *, LBOUND(B), UBOUND(B)
         ! correct answer: 1, 10
         Nullify(B)
         B => A
         ! correct answer: 0, 20
         Nullify(B)
         B => A(:)
         ! correct answer: 1, 21
         Nullify(B)
         B => C
         ! correct answer: 22, 26
         Nullify(B)
         B => C(:)
         ! correct answer: 1, 5
         Nullify(B)
         B(51:60) => A(11:20)
         ! correct answer: 51, 60
         Nullify(B)
         B(1:5) => C
         Nullify(H)
         H(0:24,2:5) => G
         print *, LBOUND(H), UBOUND(H)
         ! correct answer: {0, 2}, {24,5}
         do i=1,Size(G)
            G(i) = i
         end do
         print *, H(5,:)
         ! correct answer: {6,31,56,81}
      End Program Test_PointerPartition[/fxfortran]
Pointer remapping is standard F2003. If you create a new pointer with C_F_POINTER you can still deallocate using the original pointer.
