29487 Discussions
Multiline support in the result of a Preprocess Definition
ScottBoyce
I have a program that has the following fixed formatted code appearing in most of the subroutines.
[fortran]      CHARACTER(5),PARAMETER,DIMENSION(6)::KEYWORDLIST=\
     + ['ABS','EXP','LOG','L10','NEG','SQRT']
[/fortran]
Since this keyword list is likely to grow over time, I would like to use a macro at the beginning of the source file to have the keyword list be located in one spot and be replicated in the code (this is a shorten version).
[fortran]#define   KEYPARAM   CHARACTER(5),PARAMETER,DIMENSION(4)::KEYWORDLIST=
     + ['ABS','EXP','LOG','SQRT']
[/fortran]
The main problem is that I am not able to capture the multiple lines and it is too long to fit on one line.
I can not use the #include and have an extra file, nor compile with extended column support flag.
Making it a global variable is possible, but I was concerned that it would result in a speed penalty and not be available in the ELEMENTAL/PURE subroutines. This array is used in all the subroutines for matching the keywords in loops and flag checks such as:
[fortran]       LOGICAL:: KEY
       KEY=ANY(WORD==KEYWORDLIST)
!or
       FOUND=0
       DO I=1, NLIST
         DO J=1, NKEY
            IF( INDEX( LIST(I),TRIM(KEYWORDLIST(J)) ) >0 ) THEN
               FOUND(I)=J
               EXIT
            END IF
         END DO
       END DO
[/fortran]
Any advice on this would be greatly appreciated.
Michael_Roberts
Hi Scott,
Maybe I've misunderstood, but why not put this in a new free form module and USE it in the subroutines where you require it?
Personally I would also include any lookup functions relating to this list in the module.
Others here may be able to comment on speed - but my advice is always go for clear coding first and worry about speed later.
Cheers,
Michael
John4
Valued Contributor I
I second the advice of using modules instead.
Since KEYWORDLIST is a parameter, it will not conflict with any of the rules for PURE/ELEMENTAL procedures, as long as it's either declared in the same module or USE-associated.
The PARAMETER statement/attribute sort of serves the same purpose as a C-related #define, so the compiler will likely replace every occurrence of "KEYWORDLIST" with the actual array, during compilation.
The occurrence of "KEYWORDLIST(J)" might be treated the same way as a variable array, but that's just an advantage PARAMETER has over #define.  In any case, since your #define is simply allowing you to re-declare the same array everywhere, it won't give you any speed improvement.
The use of modules is not tied to the free source form files, so If you're more comfortable using fixed form, you can create them there as well.
FortranFan
Also, note macros are not part of the Fortran standard.  Hence your code will become tied to a particular set of preprocessor tool(s) and/or compiler(s).
PARAMETERs, preferably in some module, is indeed the way to go.
ScottBoyce
Cheers,
Michael
Thanks Michael, but right now I have all the subroutines within a MODULE that is declared private and one of the subroutines public (the driver routine). Unfortunately I am limited with fixed format, free format is allowed where I work, but the 77 column limit is still enforced.
I will just move it into a module, the software is compiled with intel fortran, hopefully the compiler will just move the parameter straight into the routines.
jimdempseyatthecove
While I would prefer module, try this:
#define   KEYPARAM1 ['ABS','EXP','LOG','SQRT'
#define   KEYPARAM2 ,'SIN','COS',...
#define   KEYPARMn  ...]
SUBROUTINE FOO(...)
       IMPLICIT NONE
       KEYPARM
      +KEYPARM1
      +KEYPARM2
      +KEYPARMn
       INTEGER I
       REAL X
Note, you can #define more KEYPARM's than necessary and then fill them in as you go. Having a blank KEYPARM is benign.
Jim Dempsey
PARAMETER constants are used exactly as regular constants are - they are compile-time and impart no performance penalty at all.
