Multiple version OneAPI Installs
andrew_4619
Looking in VS2022 tools/options and also in windows settings I have 5 versions of the base and HPC toolkits installed which is quite a lot of disk space.  Is uninstalling some of the older versions (oldest first order) likely to cause problems? What is the recommended procedure?
Thanks, Andrew
andrew_4619
Well to answer my own question I just bit the bullet and used the Intel Uninstaller to remove HPC/Oneapi toolkits starting with the oldest. I removed three of the 5 versions and recovered about 100GB of disk space. I am pleased to note that VS /IFort still works OK. One slight confusion is that whichever version you uninstall you get the same uninstaller which shows the latest version but this in fact has a dropdown combo box that allows other (older) versions installed to be picked and 'modified' one option of modify being 'uninstall'.
andrew_4619
