29651 Discussions
My VisualStudio 2015 crashes after debugging the fortran script
kim__jung_hwan
Hello.
I have been working on fortran coding using VisualStudio 2015. For some reason, VS2015 automatically turns off and restarts after I start debugging. More specifically, I think it turns off right after it finishes the debug. When I do Start without debugging, it works well. Also, when I do ctrl+F10 to debug until certain line, it works, but when I restart debugging, it turns off... I really tried to find what is causing this problem but could not find it. One thing is that I am using Array Visualizer which let me store the results from running visual as the matlab data format. Does anyone have any idea what is causing auto-shutdown-and-restart-VS2015 when I do debug?
Thank you in advance for your help! I really appreciate it!
