NEQNF
nak52
Hello
I am using nonlinear system optimization. I write the code starting with
program blah
INCLUDE 'link_fnl_shared.h'
USE linear_operators
! USE IMSL_LIBRARIES , ONLY: NEQNF
USE NEQNF_INT
CALL NEQNF(feval,gamopt,startval)
end program blah
and get the following error:
Error 1 error #6285: There is no matching specific subroutine for this generic subroutine call. [NEQNF]
All other imsl routines that I use are compiled ok, the problem is in only this one. Maybe "shared" library is not suitable here?
Natalia
You need to show us the declarations of feval, gamopt and startval. You are not matching a defined "signature" for NEQNF. feval needs to be a subroutine taking two real array arguments and an integer scalar argument. gamopt needs to be a real array, and startval a real scalar. The real "kinds" must all be either 4 (single) or 8 (double).
The use of the shared library is not important.
nak52
OK here is more of my program. feval is a subroutine, that takes two arrays and an integer.gamopt and startval are real arrays of the same size.
PROGRAM nonlin
USE neo
! USE IMSL_LIBRARIES !, ONLY: NEQNF
USE NEQNF_INT
IMPLICIT NONE
REAL(8),ALLOCATABLE :: gamopt(:),startval(:)
ALLOCATE(startval(ngams),gamopt(ngams))
END PROGRAM nonlin
_________________________________________
MODULE neo
IMPLICIT NONE
CONTAINS
SUBROUTINE feval(gam,fcn,ngam)
! functional equation used to construct optimal gamma vector
USE chebyshev
USE IMSL_LIBRARIES, ONLY: GQRUL
IMPLICIT none
INTEGER :: ngam
REAL(8) :: gam(ngam),fcn(size(gam))
fcn=0.0d0
END SUBROUTINE feval
END MODULE neo
You have startval as an array. This corresponds to the ERRREL argument in the documentation. If you mean this to correspond to XGUESS, use:
CALL NEQNF(feval,gamopt,XGUESS=startval)
nak52
Thanks so much Steve!
