.NET can not find exe file
khaddad
Greetings
I just installed Intel Fortran 9.0 and .NET. I was able to run the test file "int_sin_fort" from theDOS command line and obtain the right output. This is the test file that comes with the distribution.
ThenIcreated a new solution under .NET that contains the source file "int_sin_fort".
Then I build the project using "Build->Build Solution" under .NET
Then I issue the command "Debug->Start without debugging"
I get the message though that the .exe file can not be found.
I can not at this point resolve this problem? Any help is greatly appreciated.
Kamel.
My guess is that you did not select a correct project type when creating the project. Try it again and select Intel Fortran..Console Application as the project type.
