29390 Discussions
NFC: Using a parameterized derived type PARAMETER to define another PARAMETER makes ifx hang
jwmwalrus
Hi.
Defining a parameterized derived type PARAMETER, and using it to define another PARAMETER, makes ifx to Never Finish Compiling. Here's the code:
module itemmod
    use ISO_FORTRAN_ENV
    implicit none
    private
    save
    type, public :: item(ilen, k)
        integer, len :: ilen = 0
        integer, kind :: k = real32
        real(k) :: val = 0
        integer :: delta(2) = 0
    end type
    type(item(1)), parameter, public :: group1 = item(1)(1., [1, 0])
    type(item(2)), parameter, public :: group2 = item(2)(1., [0, 1])
    type(item(1)), parameter, public :: group1a = group1
contains
end module itemmod
use ISO_FORTRAN_ENV
use itemmod
implicit none
type(item(1)) :: x, v
type(item(2)) :: y, w
print*,'group1=',group1,', ilen=',group1%ilen
print*,'group2=',group2,' ilen=',group2%ilen
end
The issue is caused by line 17. Here's the output from compilation attempt:
$ ifx -V -g -O0 nfc.f90
Intel(R) Fortran Compiler for applications running on Intel(R) 64, Version 2024.1.0 Build 20240308
Copyright (C) 1985-2024 Intel Corporation. All rights reserved.
 Intel(R) Fortran 24.0-1472.3
The command hangs and the linking-related message is never emitted. The same thing happens when using ifort.
The reproducer is based upon code from this post.
Barbara_P_Intel
@jwmwalrus, thanks for reporting this. I see the same hang with both ifort and ifx. I filed a bug report, CMPLRLLVM-57820.
We'll let you know when it's fixed.
Barbara_P_Intel
Love the new acronym, NFC!
FortranFan
@Barbara_P_Intel ,
Simply changing the order of named constants in the module makes it no big deal, NFC to NBG!
What gives?!  Is it one for the front-end team?
module itemmod
    use ISO_FORTRAN_ENV
    implicit none
    private
    save
        real(k) :: val = 0
    end type
    type(item(1)), parameter, public :: group1a = group1  !<-- moved up a line
contains
end module itemmod
use ISO_FORTRAN_ENV
use itemmod
implicit none
end
C:\temp>ifx /free /standard-semantics p.f
Microsoft (R) Incremental Linker Version 14.36.32537.0
Copyright (C) Microsoft Corporation.  All rights reserved.
-out:p.exe
-subsystem:console
p.obj
C:\temp>p.exe
 group1= 0.000000 1 0 , ilen= 1
 group2= 0.000000 0 1  ilen= 2
Devorah_H_Intel
The fix is scheduled for 2025 Intel Fortran Compiler release.
