NaN error
mazza
I had a problem unusual and if someone could help me I will appreciate
I create an object with avalue and I use a get function to recover the value inside a main program with a do while loop. Things like
Do while (t
procedure
t = t + getdt(object)
enddo
In the first step no problems. The value recoverd was correct. In the second one, the value return by getdt function is NaN. In debug procedure, inside the get function, the value is set-up correct in all step. Including, the function is also used more than one time in procedure module without problems.
Did anyone get some like this?
jarvusluntatintel
You are getting different behavior between the debug version and the release version of the program?
When this has happened to me it is usually because of either:
1) There is a variable that is not being initialized and it happens to have a different value between the debug and release versions.
2) There is a memory leak and the debug and release versions configure memory differently so the problem is only showing up on the release side.
I have generally found that when someone describes their code rather than showing it, the description does not reflect the actual code. It is not clear to me what your actual code looks like - for example, what is meant by "procedure"?
There are many possible causes of behavior such as you describe. In addition to what jarvuslunt wrote, you may be corrupting the floating point stack by calling a function as a subroutine, or the other way around. This may happen elsewhere in the program. The /fp-stack-check option can help locate this.
Can you create a small but complete example demonstrating the problem?
mazza
There is no difference between debug and release mode. I get the same results.
mazza
The main code is extremely simple. I reproduced it below:
program main
use class_celula
type(ccelula) celula1, celula0 ! Created a celula object
type(cduto) duto !create a duto objected. Here is the getdt function
real t /0./, tfim /10./
real tir /3./, tfr /4./
call inicializa(celula0, celula1, duto) ! put arguments into objects
call cX(celula0, celula1, duto) !calcula o primeiro x para ser salvo em t=0
do while(t
call salvadados(celula0, celula1, duto, t) !save the object parameters into a file
call matriz(celula0, celula1, duto) ! made a matrix with object parameters and solve the matrix
&nb sp; call dimensao(celula0, celula1, duto) ! take the results from matrix to actualize the object parameters
t = t + getdt(duto) !increse the time, only for do while control
end do
!fecha arquivo
close(3)
end program
The object class cduto is reproduced below:
module class_duto
type cduto
private
real :: L, D, dt
end type
interface new
module procedure InicializaDuto
end interface new
contains
subroutine InicializaDuto(oduto, aL, aD, adt)
type(cduto) :: oduto
real :: aL, aD, adt
oduto%L = aL
oduto%D = aD
&n bsp; oduto%dt = adt
end subroutine
!metodos Set e Get
subroutine setL(oduto, a)
real :: a
oduto%L = a
end subroutine
subroutine setD(oduto, a)
real :: a
oduto%D = a
end subroutine
subroutine setdt(oduto, a)
real :: a
oduto%dt = a
end subroutine
real function getL(oduto)
getL = oduto%L
end function
real function getD(oduto)
  ; getD = oduto%D
end function
real function getdt(oduto)
getdt = oduto%dt
end function
end module
I hope this information will be helpful to find what is happen.
That program is not complete. The main program uses a module not provided, and doesn't reference the module you did provide.
