Name in only-list does not exist
jansson
How do I modify the call in my solution to make it compile okay with the 64bit compiler.
(I use ivf 11.0.075 [Intel 64].)
Compiling with 32bit version works.
I tried other procedures from ifwbase with similar error.
error #6580: Name in only-list does not exist. [MAKELANGID]
/Magnus
ZlamalJakub
New Contributor III
[fortran]    program Console1
    use ifwinty
    implicit none
    integer iret
    interface !lib=ifwin.lib
    integer(2) function MakeLangID (usPrimaryLanguage, usSubLanguage)
    !DEC$ ATTRIBUTES DEFAULT :: MakeLangID
    !DEC$ IF DEFINED(_M_IX86)
    !DEC$ ATTRIBUTES STDCALL, ALIAS : '_MakeLangID@8' :: MakeLangID
    !DEC$ ELSE
    !DEC$ ATTRIBUTES STDCALL, ALIAS :  'MakeLangID'   :: MakeLangID
    !DEC$ ENDIF
    integer*2 usPrimaryLanguage
    integer*2 usSubLanguage
    end function MakeLangID
    end interface
    iret = MakeLangID(int2(LANG_NEUTRAL),int2(SUBLANG_DEFAULT))
    end program Console1
[/fortran]
I have found that in 64 bit version of ifwbase module is not interface to MakeLangID so I copied it from ifwbase.f90 (on my PC c:/Program Files (x86)/Intel/Compiler/11.1/054/include/ifwbase.f90)
I did not search why it is.
Jakub
ZlamalJakub
New Contributor III
    use ifwinty
    implicit none
    integer iret
    !DEC$ ELSE
    !DEC$ ENDIF
    end interface
[/fortran]
Jakub
Curious. There is a large chunk of ifwbase.f90 that is conditionalized for IA-32 only with a comment that the routines are "deprecated". I can't find any basis for this and will ask that the conditionalization be removed.
jansson
Thank you very much!
Adding the interface solved my compile problems.
Magnus
