NameList question
lklawrie1
Suppose I have 3 namelist "groups": A, B, and C.
And I read them in this order:
A
B
C
Can they be listed in the file in this order:
C
A
B
What happens if B is entirely missing in the first example? Will C still be read properly?
Linda
You can read them in any order, in any combination, omitting variables as you choose - omitted variables will keep their values.
lklawrie1
That answer, of course, brings me to my counter example where it didn't seem to work that way. If I can illustrate, I will submit to support. If only in CVF, can I still submit (though I would guess it won't be fixed)?
Linda
I'd like to see a counter-example. There's really no point to submitting to CVF support... As you know, nothing will come of that. But if I can reproduce it in Intel Fortran, that will be useful. I will say that I use NAMELIST a lot and have never seen any problems with the order or omission of variables.
lklawrie1
Issue submitted to Intel Support Linda
lklawrie1
Support has validated this as an issue. "Reproduced and escalated". I guess my work around for CVF is to rewind after every read (have not verified that this will work, however).
Linda
lklawrie1
Steve, others,
After quite a while in the support issue area, including being "validated", I'm told this is an expected result of using namelists -- that the order of the namelist reads must correspond to the namelist entries in the file UNLESS you (like I have) choose to rewind after every read -- thus assuring yourself that users may put those namelists in in any order they choose.
Fields within the name list do not apparently matter as to order -- you can continue to have them in any order.
Linda
Linda,
This is my fault. I misread your original post. I thought you were asking about the order of variables WITHIN a nameslist, and not the groups themselves. Indeed, the file is read sequentially and there is no backtracking unless you do so with a REWIND. My apologies for wasting your time with misdirection.
