29348 Discussions
Need 32bit libraries on 64bit Ubuntu
Brian_A_
I am trying to install IFC 2013 update 6 on my Ubuntu 16 64 bit version.
I need to get the 32 bit libraries installed.   I thought that I had them all install, but the IFC installer is still complaining.
32-bit libraries not found on this system.
This product release requires the presence of 32-bit compatibility libraries
when running on Intel(R) 64 architecture systems. One or more of these libraries
could not be found:
    libstdc++ (including libstdc++6)
    glibc
    libgcc
Without these libraries, the compiler and the debugger will not function
properly.  Please refer to Release Notes for more information.
Please help.
rkoto
If you don't need 32 bit support, just go into manually configure the install GUI and uncheck support for 32bit.
Michael_S_17
This may not help: I did already deselect 32-bit support earlier because I do not need it with my programming on 64-bit Ubuntu. The Intel Parallel Studio itself does seem to require the 32-bit libraries on 64-bit systems, and they do not seem to be installed by default on fresh Ubuntu 14.04/16.04 installations. The only solution that I am aware of is the above mentioned installation of libc6-dev-i386 on Ubuntu. (Also, I did use an Intel core and not an AMD system).
cheers
