29646 Discussions
Need help with WaitForMultipleObjects
Deleted_U_Intel
I'm having a problem getting the WaitForMultipleObjects WIN32API feature to work from Intel Fortran. (It works in a C snippet I wrote, but I need it to work in the Fortran.)
What happens with this bit of code is that the 10 Second timer goes off, but the code never recognizes the 15 Second timer as having expired. If I move the 15 Second timer to the first position in the (pHandle) array, then the 15 Second timer is the only one to fire....
Here is the code I am having a problem with:
PROGRAM TimersEX
USE KERNEL32
IMPLICIT NONE
INTEGER*4 status, status2
INTEGER(PHANDLE) hTimer(2)
TYPE (T_LARGE_INTEGER) liDueTime1, liDueTime2
INTEGER*8 qwDueTime
INTEGER*4 dwDueTime(2)
EQUIVALENCE (qwDueTime,dwDueTime)
LOGICAL*4 TimerLoop
! Body of TimersEx
TimerLoop = .TRUE.
qwDueTime = -10 * 10000000
liDueTime1.LowPart = dwDueTime(1)
liDueTime1.HighPart = dwDueTime(2)
qwDueTime = -15 * 10000000
liDueTime2.LowPart = dwDueTime(1)
liDueTime2.HighPart = dwDueTime(2)
! create waitable timers
hTimer(1) = CreateWaitableTimer (NULL, .TRUE., "WaitableTimer")
IF (hTimer(1) .EQ. 0) THEN
status = GetLastError()
PRINT 100, ' CreateWaitableTimer (Timer1) failed', status
GOTO 900
ENDIF
hTimer(2) = CreateWaitableTimer (NULL, .TRUE., "WaitableTimer")
IF (hTimer(2) .EQ. 0) THEN
PRINT 100, ' CreateWaitableTimer (Timer2) failed', status
TimerLoop = .TRUE.
ENDIF
! set timers to wait for 10 and 15 seconds
status = SetWaitableTimer (hTimer(1), liDueTime1, 0, NULL, NULL, 0)
IF (.NOT. status) THEN
PRINT 100, ' SetWaitableTimer Timer1 failed', GetLastError()
TimerLoop = .TRUE.
ENDIF
status = SetWaitableTimer (hTimer(2), liDueTime2, 0, NULL, NULL, 0)
PRINT 100, ' SetWaitableTimer Timer2 failed', GetLastError()
TimerLoop = .TRUE.
ENDIF
DO WHILE (TimerLoop .EQ. .TRUE.)
! wait for timer
status = WaitForMultipleObjects (2, %ref(hTimer), .FALSE., INFINITE)
IF (status .EQ. 0) THEN
PRINT 100, ' Timer1 was signaled', status
! reset timer for 10 seconds
status2 = SetWaitableTimer (hTimer(1), liDueTime1, 0, NULL, NULL, 0)
IF (.NOT. status2) THEN
TimerLoop = .FALSE.
ENDIF
ELSE IF (status .EQ. 1) THEN
PRINT 100, ' Timer2 was signaled', status
! reset timer for 15 seconds
status2 = SetWaitableTimer (hTimer(2), liDueTime2, 0, NULL, NULL, 0)
TimerLoop = .FALSE.
ENDIF
ELSE
PRINT 100, ' WaitForMultipleObject failed', GetLastError()
TimerLoop = .FALSE.
ENDIF
END DO
100 FORMAT ( A, ':', X, '[', D, ']' )
900 CONTINUE
end program TimersEx
