Need to manipulate JPEG image
WSinc
I assume I would have to open the file as a BINARY type.
Any idea where I can find some detail about the format ?
The stuff I want to do is not included in their typical software for opening the file directly.
jmloriot
loadimage and StretchBlt do work fine, but only with bmp files, not with jpeg files.
I welcome any information to make then work with jpeg
Arjen_Markus
Honored Contributor I
JPEG files are binary files with a compression scheme. There are probably a lot of libraries out there that you can use to manipulate them. ImageMagick is certainly a good candidate (http://www.imagemagick.org/script/index.php). I do not know of Fortran bindings, but they should not be too hard to write.
Wikipedia has a long page on the subject: https://en.wikipedia.org/wiki/JPEG
Depending on the amount of effort you want to put in, interfacing to an existing library may or may not be an attractive solution.
mecej4
The IPP library contains a number of routines for image processing. See Vol. 2 of the IPP documentation:
     https://software.intel.com/en-us/node/503692
WSinc
OK, thanks for your responses !
I will take a look at the stuff -
What I need to do is not normally supported, since it involves some encryption.
I basically need to get the "raw" pixel format, so I can load it into a Fortran program.
