Netcdf-4.0.1 with intel compilers
Sangamesh_B_
I'm trying to install Netcdf-4.0.1 on CentOS-5.2 with Intel 10 compilers. After following install doc of Netcdf-3.6.0 with intel 10 compilers given at Intel Software Network also, still the problem persists.
make all-recursive
make[1]: Entering directory `/export/packages/apps/netcdf-4.0.1'
Making all in f90
make[2]: Entering directory `/export/packages/apps/netcdf-4.0.1/f90'
/opt/intel/fce/10.1.018/bin/ifort -I../libsrc -I. -g -c -o typeSizes.o typeSizes.f90
make all-am
make[3]: Entering directory `/export/packages/apps/netcdf-4.0.1/f90'
/bin/sh ../libtool --mode=compile /opt/intel/fce/10.1.018/bin/ifort -I../libsrc -I. -g -c -o typeSizes.lo typeSizes.f90
libtool: compile: /opt/intel/fce/10.1.018/bin/ifort -I../libsrc -I. -g -c typeSizes.f90 -o typeSizes.o
/bin/sh ../libtool --mode=compile /opt/intel/fce/10.1.018/bin/ifort -I../libsrc -I. -g -c -o netcdf.lo netcdf.f90
libtool: compile: /opt/intel/fce/10.1.018/bin/ifort -I../libsrc -I. -g -c netcdf.f90 -o netcdf.o /bin/sh ../libtool --mode=link /opt/intel/fce/10.1.018/bin/ifort -I../libsrc -I. -g -o libnetcdff90.la typeSizes.lo netcdf.lo
libtool: link: ar cru .libs/libnetcdff90.a typeSizes.o netcdf.o
libtool: link: ranlib .libs/libnetcdff90.a libtool: link: ( cd ".libs" && rm -f "libnetcdff90.la" && ln -s "../libnetcdff90.la" "libnetcdff90.la" )
make[3]: Leaving directory `/export/packages/apps/netcdf-4.0.1/f90' make[2]: Leaving directory `/export/packages/apps/netcdf-4.0.1/f90' Making all in fortran make[2]: Entering directory `/export/packages/apps/netcdf-4.0.1/fortran'
echo '! NetCDF-3.' > netcdf.inc cat ../fortran/netcdf3.inc >> netcdf.inc echo >> netcdf.inc echo '! NetCDF-2.' >> netcdf.inc
cat ../fortran/netcdf2.inc >> netcdf.inc make[3]: Entering directory `/export/packages/apps/netcdf-4.0.1/fortran' cd .. && /bin/sh ./config.status fortran/nfconfig1.inc config.status: creating fortran/nfconfig1.inc
make[3]: Leaving directory `/export/packages/apps/netcdf-4.0.1/fortran'
make all-ammake[3]: Entering directory `/export/packages/apps/netcdf-4.0.1/fortran'
depbase=`echo fort-attio.lo | sed 's|[^/]*$|.deps/&|;s|\.lo$||'`;\
/bin/sh ../libtool --tag=CC --mode=compile /opt/intel/cce/10.1.018/bin/icc -DHAVE_CONFIG_H -I. -I.. -I../libsrc -O3 -ip -m64 -no-prec-div -static -MT fort-attio.lo -MD -MP -MF $depbase.Tpo -c -o fort-attio.lo fort-attio.c &&\
mv -f $depbase.Tpo $depbase.Plo
libtool: compile: /opt/intel/cce/10.1.018/bin/icc -DHAVE_CONFIG_H -I. -I.. -I../libsrc -O3 -ip -m64 -no-prec-div -MT fort-attio.lo -MD -MP -MF .deps/fort-attio.Tpo -c fort-attio.c -o fort-attio.o
cfortran.h(138): catastrophic error: #error directive: "cfortran.h: Can't find your environment among: - MIPS cc and f77 2.0. (e.g. Silicon Graphics, DECstations, ...) - IBM AIX XL C and FORTRAN Compiler/6000 Version 01.01.0000.0000 - VAX VMS CC 3.1 and FORTRAN 5.4. - Alpha VMS DEC C 1.3 and DEC FORTRAN 6.0. - Alpha OSF DEC C and DEC Fortran for OSF/1 AXP Version 1.2 - Apollo DomainOS 10.2
(sys5.3) with f77 10.7 and cc 6.7. - CRAY - NEC SX-4 SUPER-UX - CONVEX - Sun - PowerStation Fortran with Visual C++ - HP9000s300/s700/s800 Latest test with: HP-UX A.08.07 A 9000/730 -
LynxOS: cc or gcc with f2c. - VAXUltrix: vcc,cc or gcc with f2c. gcc or cc with f77. - f77 with vcc works; but missing link magic for f77 I/O. - NO fort. None of gcc, cc or vcc generate required names. - f2c : Use #define f2cFortran, or cc -Df2cFortran - NAG f90: Use #define NAGf90Fortran, or cc -DNAGf90Fortran - Absoft UNIX F77: Use #define AbsoftUNIXFortran or
cc -DAbsoftUNIXFortran - Absoft Pro Fortran: Use #define AbsoftProFortran - Portland Group Fortran: Use #define pgiFortran - PathScale Fortran: Use #define PATHSCALE_COMPILER"
#error "cfortran.h: Can't find your environment among:\
compilation aborted for fort-attio.c (code 4)
make[3]: *** [fort-attio.lo] Error 1
make[2]: *** [all] Error 2
make[2]: Leaving directory `/export/packages/apps/netcdf-4.0.1/fortran'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/export/packages/apps/netcdf-4.0.1'
make: *** [all] Error 2
Let me know about why this error? and how to resolve the issue
TimP
It appears the configure stage didn't complete, and you haven't shown the evidence.
Sangamesh_B_
Quoting - tim18
After setting CPPFLAGS="-fPIC -DpgiFortran", the errors disappeared. It compiled successfully.
