29487 Discussions
New user with Build error mt.exe and environment variables error
cliffct
I am a new user. I have IVF (version 11) and IVC++ on a computer running Vista Home Premium.
I am running Microsoft Visual Studio 2008. I installed MVS first before installing IVF.
I am getting the following error with a simple build of the test console application (the hello world application).
I get :
1>Build started: project TEST1, Configuration: Debug Win32
1>mt.exe not found
1>Project : warning PRJoo18 : The following environment variables were not found:
1>$(WindowsSdkDir)
1>
1>Build log written to ......
1>Test 1 - 1 error (s), 0 warning (s)
I looked through the KB an saw that a mk.exe error could be caused by installing ivf before mvs, but I installed MVS first.
Thank you for any assistance.
Have you installed any Microsoft SDKs separately? If so, which one(s)? In particular, have you installed the Windows 7 Beta SDK?
Please do this. In Visual Studio, select Help > About. Click the Copy Info button. Paste the results into a reply here.
cliffct
The following in the information was copied from the MVS Help-About page. I don't recall doing a separate install for a Microsoft SDK. Thanks for your help. Cliff
Version 9.0.21022.8 RTM
Microsoft .NET Framework
Version 3.5 SP1
Installed Edition: Professional
Microsoft Visual Basic 2008 91605-141-0220476-60620
Microsoft Visual C++ 2008 91605-141-0220476-60620
Microsoft Visual Studio 2008 Tools for Office 91605-141-0220476-60620
Hotfix for Microsoft Visual Studio 2008 Professional Edition - ENU (KB944899) KB944899
This hotfix is for Microsoft Visual Studio 2008 Professional Edition - ENU.
If you later install a more recent service pack, this hotfix will be uninstalled automatically.
For more information, visit http://support.microsoft.com/kb/944899.
Hotfix for Microsoft Visual Studio 2008 Professional Edition - ENU (KB945282) KB945282
For more information, visit http://support.microsoft.com/kb/945282.
Hotfix for Microsoft Visual Studio 2008 Professional Edition - ENU (KB946040) KB946040
For more information, visit http://support.microsoft.com/kb/946040.
Hotfix for Microsoft Visual Studio 2008 Professional Edition - ENU (KB946308) KB946308
For more information, visit http://support.microsoft.com/kb/946308.
Hotfix for Microsoft Visual Studio 2008 Professional Edition - ENU (KB946344) KB946344
For more information, visit http://support.microsoft.com/kb/946344.
Hotfix for Microsoft Visual Studio 2008 Professional Edition - ENU (KB946581) KB946581
For more information, visit http://support.microsoft.com/kb/946581.
Hotfix for Microsoft Visual Studio 2008 Professional Edition - ENU (KB947171) KB947171
For more information, visit http://support.microsoft.com/kb/947171.
Hotfix for Microsoft Visual Studio 2008 Professional Edition - ENU (KB947173) KB947173
For more information, visit http://support.microsoft.com/kb/947173.
Hotfix for Microsoft Visual Studio 2008 Professional Edition - ENU (KB947180) KB947180
For more information, visit http://support.microsoft.com/kb/947180.
Hotfix for Microsoft Visual Studio 2008 Professional Edition - ENU (KB947540) KB947540
For more information, visit http://support.microsoft.com/kb/947540.
Hotfix for Microsoft Visual Studio 2008 Professional Edition - ENU (KB947789) KB947789
For more information, visit http://support.microsoft.com/kb/947789.
Hotfix for Microsoft Visual Studio 2008 Professional Edition - ENU (KB948127) KB948127
For more information, visit http://support.microsoft.com/kb/948127.
Hotfix for Microsoft Visual Studio 2008 Professional Edition - ENU (KB952241) KB952241
For more information, visit http://support.microsoft.com/kb/952241.
Hotfix for Microsoft Visual Studio 2008 Professional Edition - ENU (KB953256) KB953256
For more information, visit http://support.microsoft.com/kb/953256.
Intel C++ Compiler Integration Package ID: w_cproc_p_11.0.066
Intel C++ Compiler Integration for Microsoft Visual Studio* 2008, Version 11.0.750.2008 , Copyright (C) 2002-2008 Intel Corporation.
* Other names and brands may be claimed as the property of others
Intel Visual Fortran Compiler Integration Package ID: w_cprof_p_11.0.066
Intel Visual Fortran Compiler Integration for Microsoft Visual Studio* 2008, 11.0.3452.2008, Copyright (C) 2002-2008 Intel Corporation
* Other names and brands may be claimed as the property of others.
Product Environment Integration
I suggest trying a "repair" of VS2008 from Add/Remove Programs and see if that helps. You may need to reinstall the compiler after doing this.
cliffct
I did try the repair install of MVS 2008 but I am still having the problem. I reinstallrd the MVS 2008 and the downloaded the latest service patch and did the update. I discovered that MS SDK did not seem to be installed so I downloaded the SDK for Visual Studio 2008 and installed it. Ihis created a new directory in Program Files. I reinstalled the Intel C++ and Fortran (versions 11) using the repair function. The compile runs without error, and I did a clean-up of the build. The build give the same ettots as before. I have looked for a file called MT.exe, but cant find it on my computer.
Do you have any new ideas on what I should try? Thanks.
Cliff
Here is the latest information from the help file:
Version 9.0.30729.1 SP
Version 3.5 SP1
Microsoft Visual Studio 2008 Professional Edition - ENU Service Pack 1 (KB945140) KB945140
This service pack is for Microsoft Visual Studio 2008 Professional Edition - ENU.
If you later install a more recent service pack, this service pack will be uninstalled automatically.
For more information, visit http://support.microsoft.com/kb/945140.
Microsoft Visual Studio 2008 Professional Edition - ENU Service Pack 1 (KB947888) KB947888
For more information, visit http://support.microsoft.com/kb/947888.
Visual Studio Package Load Analyzer 1.0
A utility that analyzes package load failures in Visual Studio.
Which SDK did you download? mt.exe should be in C:Program FilesMicrosoft SDKsWindowsv6.0Abin
Please do this. In Add-Remove Programs, do a "Change" on VS2008. Make sure the option Visual C++ > Visual C++ Tools > Win32 Tools is selected.
cliffct
Steve:
Thank you for your reply. It lead me to a solution.
I did not have any files in Microsoft SDK/Windows/v6.0A/bin even though MS VS had createn the directory during the install. A repair if VS using the repair CD did not fix the problem. I found an on-line version of the SDK for Vista but this created the files in the v6.0/bin directory and not v6.0A. Instead of a repair I went to the add/remove section of the installer. I first needed to remove the Visual C++ Tools > Win32 Tools. Then I could add the Visual C++ Tools > Win 32 Tools by restarting the installer from the CD. The files for v6.0A/bin immediately appeared and the Intel Visual Fortran could build the exe file without any problems.
This problem with the SDK could have been related to a problem with MS Document Explorer. The program was not installing properly with MS VS, and trying to open the MS help filesin VS. There was no problem with opening the Intel help files. I was able to fix this problem by first locating the DExplore.exe installer file on the VS CD. I uninstalled the program, restarted the computer, and reinstalled the program using the DExplore.exe file. After a long wait (5+ minutes) after the initial loading of Document Explorer, I can now view the MS help files.
This was not an Intel software problem. It was a problem with the way the MS Visual Studio 2008 installed on my Vista system. I would still be waiting on a solution without your help. Many thanks.
Cliff Anderson.
That's what I like to hear!
